Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Walmart Oil Change?
by Talent_Keyhole - 01/18/20 12:50 AM
2EHA, jonnyb433, kzbd, 54Robert, CPA1989
70464 Registered Users
98 registered members (55hambone, Anthony, ArrestMeRedZ, Alfred_B, 4WD, 7 invisible), 2,473 guests, and 20 spiders.
Topics300,288
Posts5,172,455
Members70,464
Most Online3,728
Jan 11th, 2020
ScanGuage II and Powerstroke 6.7 problems #5227789 10/01/19 04:07 PM
M
mbacfp Offline OP
M
My 2014 Ford F550 6.7 Powerstroke diesel (cab & chassis) has been having an intermittent wrench, oil temp sensor at random. Instrument cluster goes off line...no speedometer, tachometer, oil temp, and no gear shift indicator. Truck still drives normal and eventually goes away. On my way home from a trip it did this for 30 minutes then all came back...stopped by Ford truck center to diagnose as this is the most severe incident.
[Linked Image]
[Linked Image]
[Linked Image]
Ford check everything and found nothing. Says it is the ScanGuage II causing this. So I unplugged from port. Kind of annoyed at I like to monitor regens, etc.
Will drive and monitor without ScanGuage II to confirm.
Anyone recommend anything for powerstroke 6.7 diesel? Maybe this is only a cab & chassis problem as I cannot find any issues reported anywhere.
Thought I would share. Will keep thread updated.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5227855 10/01/19 05:38 PM
bdcardinal Offline
I have heard of this before. Especially those "Snapshot" style plug-ins from insurance companies tend to cause all sorts of issues with some cars.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5227874 10/01/19 06:00 PM
M
mbacfp Offline OP
M
Really appreciate the feedback bdcardinal. Thank you.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5227885 10/01/19 06:15 PM
W
wdn Online Content
Online Content
W
I have heard of issues with Scangauge II causing weird problems I would just keep the thing disconnected and not use it. Not limited to cab and chassis or even to Fords in general. Even in Toyota forums. I know you paid good money for it. My Autel 808 scan tool has many diesel related functions on it never used because I drive a gas engine. Also not running with it connected all the time. If that many gauges are going offline or wacky but the truck runs and there are no codes, I would suspect the scan tool myself.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5227898 10/01/19 06:26 PM
M
mbacfp Offline OP
M
Good to know wdn. Thanks again all.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5228104 10/02/19 04:57 AM
R
Rat407 Offline
R
Interesting. My Scangauge II is plugged into my Chevy Cruze diesel all the time with no issues. I like to monitor regens as well. Did you contact Scangauge?
2002 Silverado 5.3 0w-20 AMSOIL
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5228237 10/02/19 08:29 AM
Cheico Offline
mbacfp I may have the fix for your problem. There is a wiring harness mounted on top of the emergency brake mount. It contains all the connections to system modules that control your gauges, 4x4, abs and many other things. It may disconnect everytime you pull the emergency brake release and it slams the foot pedal against its stop. The little bit of force may travel into that connector and separate it just enough for no signal. Also it may not disconnect completely when that happens but while traveling it may open up from bumps or bouncing down the road.
I would first reach up ontop of your emergency brake pedal mount and try and feel for that wiring harness. You can usually squeeze it together and all the trouble lights will instantly go away.
I hope that solves your problem. I dont have any pictures but I can up load one later today.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5228249 10/02/19 08:41 AM
M
mbacfp Offline OP
M
Cheico,
Interesting. It always happens after I release parking brake and go to put it into drive. Will have to take a look into that area. Really appreciate the info .
Rat407, I called ScanGuage and they said I could send it in to them for free inspection. Will keep thread updated.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5228256 10/02/19 08:50 AM
Cheico Offline
mbacfp I would suggest that from now on try and control the speed of your parking brake pedal by controlling it with your foot when you release it. You see I have been dealing with that problem since i got my 2015 truck. If that harness separates too much it can leave you stranded as the truck wont start without it connected together and it may even cause the transmission to have a fault and put you into limp mode. There is nothing worst than driving in a city and being stuck in traffic with no power, trying to get out of the way from an oncoming semi🤬.
Isn't it funny that the simplest problems cause the biggest issues.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5228270 10/02/19 09:09 AM
M
mbacfp Offline OP
M
Cheico,
Really appreciate this info. Would have never known about that...will be nice to parking break from now on. Will keep thread updated. Much appreciated.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5228424 10/02/19 12:38 PM
Cheico Offline
If anyone wants to see the location of that harness I've attached a link to a video. Tried to use my best videograpic skills.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5228622 10/02/19 03:34 PM
M
mbacfp Offline OP
M
Very much appreciated Cheico. Will look when I get home.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5228644 10/02/19 04:08 PM
M
mbacfp Offline OP
M
Found the wiring harness. I squeezed and it didn't feel loose or click in. It has happened 6 times after start up and only after releasing the parking brake then does as you describe. I think you have solved my mystery.
[Linked Image]
Had no idea this harness was right behind the parking brake. Will release parking brake slowly from now on for sure. Will keep thread updated on this matter. Cheers Cheico. Take care all.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: mbacfp] #5228883 10/02/19 07:56 PM
W
wdn Online Content
Online Content
W
Thanks Cheico I learned something useful today and I don’t even own a Ford.
Re: ScanGuage II and Powerstroke 6.7 problems [Re: wdn] #5229007 10/02/19 11:57 PM
Cheico Offline
I'm happy to have helped. It's not fair when we pay thousands of dollars for a truck, these little issue cost us more money to find and fix. If I can help someone today maybe someone can help me tomorrow. Pay it forward, what makes the world go round.
