1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
73 registered members (ArrestMeRedZ, ARB1977, amblerman, 4WD, 94astro, 40w8, 4 invisible), 1,442 guests, and 79 spiders.
Topics306,081
Posts5,287,038
Members71,596
Page 1 of 5 1 2 5
SN+ 5w40 and 0w40 oils? #5224595 09/28/19 09:45 AM
donnyj08 Offline OP
What are some good options for SN+ 40wt oils?
I’ve found 2 so far; cam2 5w40 SN+ and Amsoil SS 0w40 SN+
Any other good 40wt options for LSPI protection?
2008 Silverado LT Z71 101k PP 10w30
2016 Tucson Limited 1.6T AWD 35k M1 5w30 AP
Re: SN+ 5w40 and 0w40 oils? [Re: donnyj08] #5224610 09/28/19 10:01 AM
O
OilReport99 Online Content
Online Content
O
2018 Ram 1500 - VME 5W-20
Re: SN+ 5w40 and 0w40 oils? [Re: donnyj08] #5224624 09/28/19 10:14 AM
A
arob85 Offline
A
Chevron Delo 400 XSP SAE 5W-40. Most all of the Delo line is SN Plus rated
2019 Raptor
2008 Corvette
2000 F-150
1993 F-150
Re: SN+ 5w40 and 0w40 oils? [Re: arob85] #5224629 09/28/19 10:25 AM
donnyj08 Offline OP
Yes! I forgot about this one.
I believe they also have a 5w30 SN+ with a 3.5HTHS as well? Seems harder to find, however
Re: SN+ 5w40 and 0w40 oils? [Re: donnyj08] #5224653 09/28/19 10:57 AM
M
mightymousetech Offline
M
New formulation of Pennzoil Plat Euro is SN+.
https://shell-livedocs.com/data/published/en/3c287a5e-728b-4e26-9ec3-4d5493b711a4.pdf
It is also a full SAPS A3/B4, so should have good protection.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition PPE 5W40 MTL/MT-LV
2010 BMW 328i X-Drive, PPE 5W40 MT-LV
Re: SN+ 5w40 and 0w40 oils? [Re: donnyj08] #5224666 09/28/19 11:13 AM
CT8 Offline
Looking at the UOAs there are oils that have the additive levels that look like SN+ oils here for example
2015 F150 2.7
2018 F350 6.2
Re: SN+ 5w40 and 0w40 oils? [Re: mightymousetech] #5224675 09/28/19 11:24 AM
edyvw Offline
Next to MB229.5, Porsche A40, LL01, SN+ is irrelevant. But, it is there for crowd that think that is what matters.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: SN+ 5w40 and 0w40 oils? [Re: edyvw] #5224824 09/28/19 02:51 PM
donnyj08 Offline OP
It’s likely relevant for the crown that has very small T-GDI Engines like the Hyundai 1.6T that allows a 5w40 to be used, but could be susceptible to LSPI.
Most all the 0w40 Euro oils have high Ca Content, so options on a 40wt are limited for API LSPI protection.
Re: SN+ 5w40 and 0w40 oils? [Re: mightymousetech] #5224834 09/28/19 03:13 PM
L
Lowflyer Offline
L
What in the datasheet is approval and what recomendation?
No truly. A lot of, but not "most". No more.
And, Ca is not alone aliable for LSPI, but anyway you can balance lspi-danger with moly and magnesium. You must not go with calcium under 2000. Unless you are randy for margin and you choose feeble addpack.
For best results of course, dont buy banana-cars, with banana-engines, in whichsoever you must afterwards put banana-oils.
That's a piece of cake.
Re: SN+ 5w40 and 0w40 oils? [Re: mightymousetech] #5224842 09/28/19 03:39 PM
donnyj08 Offline OP
Thanks for this. VI of 206 is very high.
Re: SN+ 5w40 and 0w40 oils? [Re: donnyj08] #5224995 09/28/19 08:08 PM
SteveG4 Offline
Chevron Delo 400 XSP SAE 5W-30 is SN rated with an HTHS of 3.5.
As such, it is one of the few SN-rated 5W-30 oils with such a high HTHS.
It is available on Amazon in gallon jugs.
Somewhere between Alaska and Wisconsin...
2006 4WD Silverado LT Crew Cab & 2013 AWD Equinox
Re: SN+ 5w40 and 0w40 oils? [Re: SteveG4] #5225028 09/28/19 09:27 PM
SteveG4 Offline
Also, Chevron Delo 400 XSP SAE 5W-30 is also a SN PLUS oil now.
Still has an HTHS of 3.5.
Re: SN+ 5w40 and 0w40 oils? [Re: donnyj08] #5225038 09/28/19 09:57 PM
Dinoburner Offline
Without having an oil analysis before installing an oil how do we really know. Faith, past history, prejudice?
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: SN+ 5w40 and 0w40 oils? [Re: Dinoburner] #5225051 09/28/19 10:11 PM
K
kschachn Offline
K
No, specifications and approvals.
What would the VOA tell you beyond that?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: SN+ 5w40 and 0w40 oils? [Re: kschachn] #5225054 09/28/19 10:14 PM
Dinoburner Offline
point taken.
Kubota L5030 T6
Page 1 of 5 1 2 5
