Originally Posted by rekit
I see the rear is recommended by Discount. This is a Kia Optima Front WD. Going to replace the fronts. The rears are 75%. The concern is hydroplaning. I think the fronts move the water for the rears. And in the dry the fronts do all the driving and most of the breaking. What am I missing?
SPINNING ... ! Maybe. Or not ...
The tires with the least amount of tread will usually lose traction first. Especially in the wet or on snow. If you drive off the road nose first, it's YOUR fault. If you spin and fly off the road backwards, it's still your fault, but the lawyers of the world will call it the tire shops fault ... they caused the " accident ... " by putting those new tires on the front. Very dangerous ... true if the back tires are VERY worn. And that is why they won't put the new tires on the front.
Realistically, if your rear tires ARE ACTUALLY at 75 %, putting the new tires on the front shouldn't be an issue. In rain / snow, I would rather have the tires with full tread depth up front, doing that kind of important stuff like stopping, turning and accelerating, and NOT hydroplaning.
