Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
24 registered members (bmod305, Danno, blufeb95, Char Baby, Blueskies123, 3 invisible), 734 guests, and 42 spiders.
Topics306,079
Posts5,286,975
Members71,596
Page 1 of 3 1 2 3
Frustrated By Heavily Oxidized Headlights? Here's What Worked #5223999 09/27/19 01:05 PM
H
Hot_Ajax Offline OP
H
Just stumbled on an outstanding product to get rid of that ugly haze on your headlights. It took me roughly 10 minutes per light, and was a piece of cake to use. The stuff is called "Miracle Shine", made by GMS products in the People's Republic of California. I bought it about a year ago, just to clean and polish the exotic metals on my bathroom fixtures. It cleans, shines, and gets rid of all the water marks, and does a fantasic job. So, my headlights look like a little kid with a cold rubbed booger all over them. It was time to clean them. So, instead of buying a headlight restoration kit, just for kicks I grabbed the Miracle Shine. Did an absolutely amazing job. They look pretty close to new, except for the nicks in the plastic ( the truck is 11 years old, after all, and still has the same headlights which were never refinished. ). I finished it off with some wax. I'm really pleased with how they turned out, especially since I didn't have to go buy a restoration kit, and waste an afternoon using it. Caution: Remove it while it is still wet.
Probably some people will say I'm making money off the post. I'm not. For the record, I have no financial interest in "Miracle Shine". I don't sell it, don't own stock in the manufacturer, and make absolutely nothing for telling you guys about this stuff. Comes in an 8 oz squeeze bottle, and costs about $13.00. Use it on EVERYTHING that has a non-porous surface. Bottle says it is "Safe - Nonabrasive". Have fun and congratulate yourself on a job well done. Really easy to rub on.
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224014 09/27/19 01:39 PM
diyjake Offline
Is this the stuff your talking about? Miracle Shine
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: diyjake] #5224022 09/27/19 01:54 PM
H
Hot_Ajax Offline OP
H
Yep, that's the stuff. Finding it in a store is the hard part. The rest is all easy.
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224038 09/27/19 02:14 PM
W
wdn Offline
W
I use Pepsodent toothpaste, 99 cents a tube. I also brush my teeth with it.
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224066 09/27/19 03:03 PM
Z
ZraHamilton Offline
Z
If the oxidation is heavy enough, the easiest way is to wet sand the entire layer of oxidized clear coat/plastic with 400/1000/2000/2500 grit, then compound and polish with a drill polisher kit.
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: wdn] #5224080 09/27/19 03:34 PM
M
motts Offline
M
+1 paste toothpaste
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224114 09/27/19 04:26 PM
28oz Offline
Lots of things will polish them well. How long they stay clear is what counts!
1990 Nissan 300zx VG30DE - M1 EP 10W-30
2004 Nissan Quest VQ35DE - M1 EP 10W-30
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - QS HM 5W-30
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224130 09/27/19 04:55 PM
J
JeffKeryk Offline
J
Pics of the result?
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224199 09/27/19 06:33 PM
B
benjy Offline
B
about most toothpastes they should NOT be used as intended!!! search a bit you will see some VERY questionable ingredients!!
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224224 09/27/19 07:14 PM
U
Ursatdx Offline
U
I used the 3M restore kit on our 06 Pilot.
Several steps and some serious sanding and the
lights look nearly new. 1 year later they still look great.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: 28oz] #5224298 09/27/19 08:59 PM
H
Hot_Ajax Offline OP
H
Originally Posted by JeffKeryk
Pics of the result?
Understood. But since it only took about 20 mins to do the whole job, not concerned. I'll just do it again if it needs it, Faster than making breakfast.
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224319 09/27/19 09:22 PM
R
Rand Offline
R
On an old beater I used some off deep woods(deet) on a sock.. worked pretty good about 2 mins per light.
I then cleaned them really well with dawn.. let dry
wiped them down with rubbing alcohol
and sprayed them with clearcoat spraypaint... Rust-Oleum IIRC.
worked just fine but I only had that car for about 1.5 years after that.
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224384 09/27/19 11:55 PM
Dufus2 Offline
I use this stuff from Turtle Wax made for headlights (T-43) its a Headlight Cleaner and Protectant. Its not really sold in stores but Amazon has it at a low price and a bottle lasts forever. If the lights are real bad, I wet sand with 2500 and polish with a foam pad on a drill. Looks amazing when finished.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: 28oz] #5224411 09/28/19 01:12 AM
c502cid Offline
^^^this!^^^
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: Frustrated By Heavily Oxidized Headlights? Here's What Worked [Re: Hot_Ajax] #5224439 09/28/19 03:00 AM
Z
ZZman Offline
Z
There are a lot of videos on YouTube of people using various metal polishes to clean headlights.
2005 Toyota Avalon XLS 3.5 motor
2014 Ford Fusion 2.5 motor
Page 1 of 3 1 2 3
