Originally Posted by rubberchicken
========= Protect Your Hearing ===========
Wind noise in certain situations or certain bikes is a concern, so get some earplugs. +999 to BusyLittleShop.
+1
If you can't get custom ones, I'd recommend using the disposable foam ones.
For additional noise isolation, moisten your finger then insert into your ear and moisten the canal as best you can.
Then when you insert the compressed foam plug, you'll have a water-tight seal in addition to the foam.
I admit, sounds kinda gross, but makes a HUGE difference!
+1
