Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
92 registered members (94astro, aquariuscsm, 4WD, A_User55555, 330indy, 2015_PSD, 6 invisible), 2,119 guests, and 35 spiders.
Topics306,137
Posts5,288,163
Members71,604
Page 1 of 5 1 2 5
diesel oil in gasoline engines #5223079 09/26/19 01:06 PM
H
HyundaiAbuser Offline OP
H
Are there any benefits/downsides to running diesel oil in a gasoline engine? Currently looking at a 5 qt jug of 15w40 supertech for $10 in a beat up old el camino.
03 Hyundai Tiburon:
PP High Mileage 5w30
Redline MT85
94 Mazda B4000
Supertech 10w40 High Mileage (RIP)
Valvoline Maxlife
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223095 09/26/19 01:17 PM
K
kschachn Online Content
Online Content
K
It's API SN, correct?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223100 09/26/19 01:21 PM
Capt Offline
You may notice slightly more fuel consumption, most certainly less oil consumption. The add pack is usually more robust, higher tbn, more anti wear additives & detergents. My 1st choice for an old beater would be 15w-40HD.
Oh if it has a high level of Zinc or phos? it may foul up the cats (assuming it has cats & burns oil)
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223120 09/26/19 01:43 PM
A
Audios Offline
A
Should work well, go for it.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: diesel oil in gasoline engines [Re: Audios] #5223132 09/26/19 01:53 PM
L
Lolvoguy Online Shocked
Online Shocked
L
+1
I'm running Rotella T4 15w40 (also rated for diesel vehicles) in my oldie and she seems to like it.
Never had oil consumption issues, so no need to worry about the cat.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223144 09/26/19 02:14 PM
N
nthach Offline
N
Go for it. 15W-40 is my favored grade for older European engines and it's much better than a 20W-50.
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223150 09/26/19 02:23 PM
B
BigCahuna Offline
B
Harley recommends using diesel oil if your bike is low on oil, and their brand of oil isn't available. And for winter use they say to use 10/40wt when the temps are below 40f. So again 15/40 would work there also.,,,
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223157 09/26/19 02:27 PM
M
MParr Offline
M
You will be fine running it. You may notice your fuel mileage going down a little. If you live where you experience pretty cold winters, you can switch to Super Tech European 5W40.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223311 09/26/19 06:16 PM
toneydoc Offline
How beat up is the el camino?
I really love the el camino
How much do you want for her?
1994 Jeep 168k NextGen 10w30
2014 Camry 44k Castrol Magnatec 0w20
2018 Jeep Cherokee 8k Pennzoil Platinum 5w30
2014 HD Ultra 51k Mobil1 15w50
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223314 09/26/19 06:20 PM
Snagglefoot Online Content
Online Content
This question is often asked. Officially motor oils for gasoline engines are limited in the USA by The American Petroleum Institute (API) to 800 ppm for Zinc and phosphorus. They feel anything higher is damaging to catalytic convertors. However, many Bitoggers like Zinc and phosphorus so they like using oils that are meant for Diesel engines. Some say if it doesn’t burn oil it’s OK, but that is not the position of the API. However, there are no API cops peeking into your garage, so I guess you can use what you want. smile
If you want the job done right......do it yourself.
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223396 09/26/19 08:08 PM
CT8 Offline
If the 15W works for your starting temps the oil will work great.
2015 F150 2.7
2018 F350 6.2
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223414 09/26/19 08:34 PM
StarCaller Offline
Quote
check this one here
mobil1 data sheet 06-2019
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223421 09/26/19 08:40 PM
J
JeffKeryk Online Content
Online Content
J
I run Rotella T 15w40 in my classics. There are other (probably better) flat tappet oils out there.
If you are running stock valve spring rates, any 10w30 is probably fine.
If it is an original or pumped engine, I would use a specific oil for that engine.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: diesel oil in gasoline engines [Re: CT8] #5223457 09/26/19 09:06 PM
B
bbhero Offline
B
True CT8...
By the way... Way cold up your way I believe.... For the next week or so it will be quite cold in your area. A 15w might be a little thick in your area come Saturday am smile
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: diesel oil in gasoline engines [Re: HyundaiAbuser] #5223539 09/26/19 11:09 PM
dwendt44 Offline
Rotella T-6 is diesel rated and it's 5W-40.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Page 1 of 5 1 2 5
