Stupid regulations- Diesel Cap Color
by Rmay635703 - 12/12/19 08:20 AM
Help a not-so-noob: shear stability theory.
by OilStasher - 12/12/19 08:03 AM
Latest oil purchase for Lawnmowers
by Snagglefoot - 12/12/19 07:44 AM
Old school bra
by whizbyu - 12/12/19 07:10 AM
Tricky flight ticket change fees
by Superflan - 12/12/19 07:10 AM
2019 Jeep Rubicon F&R Axle UOAs [5,000 Miles]
by 2015_PSD - 12/12/19 06:58 AM
Redline SL-1. Application warning
by BMWTurboDzl - 12/12/19 06:51 AM
My Forester CVT blew up
by IMPALA08 - 12/12/19 06:30 AM
2016 Titan XD Cummins, Schaeffers 9000 5W-40
by 06_lx - 12/12/19 06:09 AM
Will moving steering via wheel hubs cause harm?
by mobilaltima - 12/12/19 12:26 AM
This oil looks interesting but not avail in US
by jkhawaii - 12/11/19 10:39 PM
Castrol Engine Shampoo (Oil Flush)
by adams355 - 12/11/19 10:03 PM
How Dumb can she get #2
by KeithS_NW_Ohio - 12/11/19 09:45 PM
Dodge Transmission
by Butterbean - 12/11/19 09:38 PM
Pay Raise
by KeithS_NW_Ohio - 12/11/19 09:17 PM
Mid-size SUVs for exploring/DD
by AZjeff - 12/11/19 09:05 PM
3.5 Ecoboost issues solved for 2018?
by JLTD - 12/11/19 08:30 PM
14 Grand Caravan Broken Exhaust Valve
by cptbarkey - 12/11/19 07:48 PM
lutvi20, Bazik, Lamasuna, berlinbai, SimpleGuy48
70111 Registered Users
95 registered members (Astro14, ARCOgraphite, 14Accent, Aero540T, alcyon, AZjeff, 7 invisible), 1,521 guests, and 20 spiders.
Topics298,617
Posts5,139,211
Members70,111
Most Online3,589
Nov 2nd, 2019
Incessant belt squeal at idle #5222596 09/25/19 09:19 PM
I
Ihatetochangeoil Offline OP
I
My daughter's car, 2004 Buick Lesabre 148K, runs like a top; I've changed serpentine belts numerous times, GM OEM #12569591, Goodyear Gatorback, Dayco, Bando, the old OEM belt back on....I have 5 belts, 4 of them less than 10K each. No matter which belt I use, it runs for awhile after being thoroughly warmed, then when you're idling like at a stoplight or in a drive thru, the belt starts howling like a banshee. It gets quiet upon slight acceleration, never a peep out of it on highway, etc.,A/C Compressor is good (per A/C only shop), water pump OEM new, belt tensioner new OEM, power steering pump smooth as butter....It's just aggravating. Tried belt dressing about 20K ago, no real help. Suggestions (other than dynamite) welcome.
Re: Incessant belt squeal at idle [Re: Ihatetochangeoil] #5222604 09/25/19 09:30 PM
G
Gebo Offline
G
Try soaking a new one overnight in 303. Not promising anything.
I use a big ziplock gallon bag and pour about a cup of 303 in with the belt. I flip it every now and then.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Incessant belt squeal at idle [Re: Ihatetochangeoil] #5222615 09/25/19 09:42 PM
M
mightymousetech Offline
M
Infind the best thing to quiet a squeaky belt is a bit of talcum powder. Often belts are noisy due to a bit of oil or grease on the belt. The talc will absorb that oil.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, BMW 0W30, MT-LV
Re: Incessant belt squeal at idle [Re: mightymousetech] #5222630 09/25/19 10:28 PM
I
I
This sounds logical. Have you actually done it/worked?
Re: Incessant belt squeal at idle [Re: Ihatetochangeoil] #5222640 09/25/19 10:50 PM
CatCam2 Offline
are you sure it isn't an idler pully??
Re: Incessant belt squeal at idle [Re: CatCam2] #5222641 09/25/19 10:59 PM
I
I
I changed out the OEM belt tensioner with a new OEM belt tensioner. No difference....
Re: Incessant belt squeal at idle [Re: Ihatetochangeoil] #5222643 09/25/19 11:13 PM
2
2strokeNorthstar Offline
2
A rusty pulley somewhere. I had an alternator pulley that was rusty/pitted and made me crazy. Swapping for new is the only thing that solved it.
2001 F150 5.4L
2013 Nissan Juke Nismo
2000 Honda S2000
1998 BMW 328i
Re: Incessant belt squeal at idle [Re: 2strokeNorthstar] #5222647 09/25/19 11:19 PM
I
I
I very much appreciate your thoughts; my pulleys are NOT rusty. Car has been garaged since new...
Re: Incessant belt squeal at idle [Re: Ihatetochangeoil] #5222651 09/25/19 11:23 PM
clinebarger Offline
Pulley misalignment? The power steering pulley is the biggest offender on GM cars & trucks especially if the pump has been changed.
2001 Chevy Camaro L92/4L80E
Re: Incessant belt squeal at idle [Re: clinebarger] #5222659 09/26/19 12:09 AM
W
Wolf359 Offline
W
Yeah, maybe a washer was missing or a bad part? Belts shouldn't go bad if everything is in alignment. Also did the OP check for play in all the pulleys with the belt off?
Re: Incessant belt squeal at idle [Re: Ihatetochangeoil] #5222697 09/26/19 04:20 AM
K
krismoriah72 Online Content
Online Content
K
You didnt list idler pulley.
Also you could suspect the belt tensioner... even though it is OEM.. every OEM one you buy may have a weak or sticky spring.
Try a different brand tensioner.
You shouldnt have to use any products on a serpentine.. you have a mechanical issue.
Re: Incessant belt squeal at idle [Re: Ihatetochangeoil] #5222746 09/26/19 06:03 AM
Snagglefoot Online Content
Online Content
With the belt off, spin each pulley and see if you can feel any roughness or hear any noise. I’ve had a water pump that had some noise, changed it out, and the squeal was gone.
If you want the job done right......do it yourself.
Re: Incessant belt squeal at idle [Re: Ihatetochangeoil] #5222752 09/26/19 06:17 AM
M
Miller88 Offline
M
Once the original belt tensioner wears out, I've never had luck with them. Even a brand new OEM one. They never keep tension right.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Incessant belt squeal at idle [Re: Ihatetochangeoil] #5222808 09/26/19 07:15 AM
W
WishIhadatruck Offline
W
Mine on my Buick wagon turned out to be an issue with the harmonic balancer going bad. We finally have peace and quiet after a few years of squealing that I could not get to go away. The harmonic balancer finally got bad enough it was obvious it needed replacing before it fell apart.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
Re: Incessant belt squeal at idle [Re: WishIhadatruck] #5222827 09/26/19 07:29 AM
K
kschachn Offline
K
Yes, this happened on my old Accord. The rubber between the two pieces of the balancer debonded and one part would move against the other. It sounded like belt squeal but all belts were new and properly tensioned.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 428K
2000 Toyota ECHO, 284K
