Why make a post and end it with the tired old "hate" statement?
The only questions I would ask is how are you determining fuel dilution in your examples? Were you having the oil tested by a lab that uses gas chromatography?
Also, a thicker oil gets hotter than a thinner one. There are more shear forces in the bearings and this warms a thicker oil up more than one than one which is thinner. It also takes more energy to move a thicker oil, that energy has to go somewhere and it is into the oil.
Originally Posted by gamefoo21
I've posted before but honest to god this was my experience with the vehicle and my relatives ran it on premium gas because the wife could tell a very noticeable difference between regular and premium just driving around.
Relatives had a 15 Fusion, 2.0 EB 6 spd slushbox with AWD. 270hp/270ftlb with 91 octane, 240hp/270ftlb with 87 octane, according to Ford.
With a full sump of Ford full synthetic 5w30 and a diet of premium aka 91 octane top tier gas... it had almost no fuel dilution issues. It would just crank the boost to go up hills on cruise at 110kph. You could hear the turbo whistle, it was a sweet song. 8.5-7L/100km on the highway.
With a sump full of their semi synthetic, it would start poisoning about half way through.
With a sump left low by Ford techs for room for fuel dilution, it would pull boost, and start poisoning right away.
With regular gas aka 87 octane, it would pull boost, pull timing the fuel economy dropped, and the oil stunk of gas. That hill would now require it to unlock the torque converter, and drop a gear. You never heard the turbo whistle and it was much groggier feeling. 10-10.5L/100km on the highway
If the oil is getting too hot, the computer pulls back to protect the turbo. When it pulls back, it starts pushing more fuel, and pulling timing...
Even modern factory vehicles are bound by the rules...
1) Good boost needs good fuel and oil
2) Thinner oils get hotter, hot oil can't keep up the viscosity to protect parts.
3) Just because it can run on 87 octane, doesn't mean it'll run it's best.
4) Running big boost with lousy gas requires compromises, and those compromises will affect things, such as running incredibly rich, which is why you get fuel dilution issues.
5) Low viscosity oil, and big boost don't get along.
I consider big boost to be more than 7psi with a base engine CR of 9:1.
It's wanted to see if 87 octane would make a measurable difference at highway speeds and I thought watching timing advance on a engine at a fixed speed/load would be telling.
So recently I decided to test just a boring 2L with 9.5:1 CR, just watching the timing advance on cruise bumping down the highway, with a fully warmed engine and as similar a situation I can manage. 115Kph, manual trans in 5th, 3200rpm(iirc) and tires at 35psi.
Timing advance results via OBD2 and Torque Pro with an OBD MX BT adapter:
87 Octane: 28 - 32 degrees, bouncing around a lot
91 Octane: 39 - 40 degrees, rarely moved
The OM of this 16V DOHC VVT engine, says to run it on 87 octane.
Edit: Yes, I realize that my post will likely garner a lot of hate, but eh, it was mine and their experience
