Found some Mobil Delvac 15W40 on rollback at walmart for about $30 for 2.5 gallons
and then found Delo 15W40 XLE on clearance for about $13/gallon....
Going in a Kubota L2501 tractor, and I am wondering if I should stock up a little....each change is just under 2 gallons worth....both prices seem pretty good...is one a better deal (or any better oil than the other?) - there is no emissions stuff on the L2501 and the recommended oil is CH or CI-4 oil with CJ-4 specifically NOT recommended (I know thats probably out of date...but for what its worth).
The semi-syn - Delo 400XLE could be worth stocking some, but I notice that now the Delvac is advertised as semi-syn also.....and if I understand correctly - almost anything can be labeled semi-syn these days...
Question is - either one worth it or nah?
