Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
40 registered members (CapriRacer, Amkeer, Danno, Char Baby, bernardch, classic70, 2 invisible), 936 guests, and 67 spiders.
Topics306,278
Posts5,289,445
Members71,616
Delvac 15W-40 or Delo 400 XLE 15W-40 #5221566 09/24/19 05:44 PM
T
tundraotto Offline OP
T
Found some Mobil Delvac 15W40 on rollback at walmart for about $30 for 2.5 gallons
and then found Delo 15W40 XLE on clearance for about $13/gallon....
Going in a Kubota L2501 tractor, and I am wondering if I should stock up a little....each change is just under 2 gallons worth....both prices seem pretty good...is one a better deal (or any better oil than the other?) - there is no emissions stuff on the L2501 and the recommended oil is CH or CI-4 oil with CJ-4 specifically NOT recommended (I know thats probably out of date...but for what its worth).
The semi-syn - Delo 400XLE could be worth stocking some, but I notice that now the Delvac is advertised as semi-syn also.....and if I understand correctly - almost anything can be labeled semi-syn these days...
Question is - either one worth it or nah?
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: tundraotto] #5221573 09/24/19 05:52 PM
O
OilReport99 Offline
O
Tractor Supply Co. has had Mobil Delvac 1300 for $8.99/Gallon for a few weeks now. Check your local store.
2018 Ram 1500 - VME 5W-20
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: OilReport99] #5221580 09/24/19 06:02 PM
T
T
Wow - even cheaper!....I had the tax included, but still - I now see that they even have a 'rebate' (I know them to sometimes work out, and other times not) for $6 off per gallon or $12.50 off per 2.5gallons).
With both being so economical right now - I just want to stock up on the better oil for my application...I know its kinda subjective....but - thoughts?
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: tundraotto] #5221590 09/24/19 06:11 PM
P
philipp10 Offline
P
I don't see a reason to stock up. It will be there next month as well.
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: tundraotto] #5221672 09/24/19 08:10 PM
W
wdn Offline
W
I have been using Delvac 1300 Super oil 15W40 in my Kubota tractor since I bought it 18 years ago and it is running fine and never had an engine issue. Have never changed brands or type of oil in that tractor since new.
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: wdn] #5221711 09/24/19 10:08 PM
T
T
That sounds like what I want....just getting greedy maybe, with the Delo XLE - never used it. Just seems so good on paper......
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: tundraotto] #5221746 09/24/19 10:50 PM
4WD Offline
After the plant upgrades … Delvac Super uses GII+ base stocks … Noack around 10
I’d take either over the cheese dip brand this cult loves…
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: 4WD] #5221764 09/24/19 11:14 PM
T
T
How does that compare to the Delo XLE? I cant find the NOACK?
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: tundraotto] #5222686 09/26/19 04:30 AM
Dak27 Offline
I don't have any experience with Delo 400 XLE 15W40, but I've used the 10W30 XLE and it did a great job. I'm not sure on the NOACK numbers, but I'm sure you could email Chevron directly and they'd give you that info. I've talked with their folks on their Lube-Tek phone number, and they were very helpful.
In my application, Pre-EPA Detroit Series 60 motor, the different variants of Delvac and Delo that I've tried performed identically in UOAs. I decided to buy the brand that was priced the lowest and was the easiest to find.
I drive long haul, and I'm usually loaded anywhere from 77,000 to 79,500 lbs GVW. I typically do my OCIs every 15,000 miles or 300 hours. I've pushed past those numbers by a little here and there, and the UOAs showed I could go even further, on both brands.
As a side note: I've been using Phillips 66 Guardol ECT 15W40 and 10W30 for close to a year and a half, roughly 175,000 miles, because I could get it for a lower price than Delo, but it's price per gallon has gone up a bit, unless I buy it in bulk. It's another solid performer.
I'll be switching back to Delvac Super 1300 15W40 and 10W30 soon. The gentleman who I'm leased on with stocks bulk 15W40 Delvac Super 1300 in his shop, and we're going to go in together on a barrel of Super 1300 10W30 for winter use. The cost per gallon of these two Delvac products are the cheapest I can find on any big name brand HDEO.
So, long story short. IMO Delo 400 and Delvac 1300 are excellent oils. Buy whichever is the easiest to find, and the lowest priced. Your engine won't notice any difference between the two, and you can rest assured whichever brand you choose will provide excellent service for your engine.
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: Dak27] #5222798 09/26/19 08:04 AM
T
T
Thanks a lot for that useful info. Reaffirming to have real world experiences, and not just reading manufacturer specs etc.
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: 4WD] #5234307 10/08/19 08:58 PM
R
Rglossip Offline
R
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: tundraotto] #5234308 10/08/19 08:59 PM
R
Rglossip Offline
R
Curios what "cheese dip brands " means?
Re: Delvac 15W-40 or Delo 400 XLE 15W-40 [Re: Rglossip] #5234565 10/09/19 07:29 AM
T
T
I take it as referring to the yellow Shell brand with the chip-looking clam logo.
