Originally Posted by Traction
The thread title said "Sure you could use anti-seize". But everyone still seems to totally ignore the effect on wheel clamping force, which is going to over-stretch the wheel stud no matter how you justify it when using lube. If it make the nut easier to turn, it is going to turn much further before it comes up to the specified torque with the stud getting longer. How can that be the best practice, especially on cars that have quality plated studs, and lug nuts that still look new for years. Rusty, poorly maintained fasteners, all bets are off. Then it's always more of just a guess when using lube. I've torqued well over 50,000 lug nuts in the last 17 years, and have seen plenty of issues, and depending on the condition of the fastener, sometimes like on a German wheel bolt a little anti-seize is needed, but not every car needs it. It's mostly common sense.
I just don't think it's a big deal. I think a lubed and torqued stud is going to suffer less damage than a stud that has an impact used on wet or dry. We don't even know how close the lugnut torque spec is to the yeild point of the stud. Overall I think if you are taking the time to torque the lugnuts it really doesn't matter if you lube them or not.
