1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
75 registered members (aba4430, Alfred_B, 69Torino, 1978elcamino, 77GrandPrix, 53' Stude, 6 invisible), 1,600 guests, and 62 spiders.
Topics306,083
Posts5,287,066
Members71,596
2018 Civic SI, 18,285 Total, 11,635 RL MTL #5220650 09/23/19 04:05 PM
CincyGTS Offline OP
2018 Honda Civic SI 6 Speed Manual Transaxle
11,635 on oil - Redline MTL
18,285 on unit
Note: BL is the virgin sample
Note: First and second fluid changes were done nearly back to back so there shouldn't be too much residual silicon at this point.
[Linked Image]
Re: 2018 Civic SI, 18,285 Total, 11,635 RL MTL [Re: CincyGTS] #5236836 10/11/19 10:32 AM
Danr42 Offline
I think all the silicon is harmless and contained in the oil and not a contaminant.
The aluminum and iron are probably still just washing out or break in.
With Honda MTF starting at 7.5 Cst and shearing down I think you could easily run this oil for 25-30K.
Is it harder to shift in the cold?
Is this 75W90? It says 75W80 in the report is that a typo?
Did you do any analysis of the factory fill with 6k on it?
Re: 2018 Civic SI, 18,285 Total, 11,635 RL MTL [Re: CincyGTS] #5272719 11/20/19 03:09 PM
CincyGTS Offline OP
Car shifts perfectly fine.
The older Honda MTF had a similar viscosity to the Redline MTL so there really isn't that much of a difference.
The Redline is a 75W80.
Re: 2018 Civic SI, 18,285 Total, 11,635 RL MTL [Re: CincyGTS] #5325586 01/17/20 07:44 PM
Marco620 Offline
If your going to track it or mash gears in the summer some use MT90 redline gl4 or mix MTL and MT90. Call Dave at Redline if you have any questions.
15' Civic r18, 335,000 mi M1 0w30/5w30 & LG Biotech,Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind, and anything vegan.
