Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
Coolant UV Dye - for without flushing
by Ndx - 05/24/20 09:10 PM
STP S8A C&P
by mpack88 - 05/24/20 07:50 PM
Aprons
by buck91 - 05/24/20 07:35 PM
Oil Additives for GDI engines
by Drew99GT - 05/24/20 07:21 PM
rickyradit, YogiTheCat, StevePLR, BBC_bias, rabblrouzr
71525 Registered Users
94 registered members (97K15004WD, 69Torino, 2009Edge, AandPDan, 53' Stude, 4WD, 8 invisible), 2,665 guests, and 22 spiders.
Topics305,842
Posts5,281,318
Members71,525
Page 1 of 4 1 2 3 4
can't patch a plugged tire? #5220401 09/23/19 11:54 AM
W
WhyMe Offline OP
W
recently got a flat on the road. broke out my plug kit and compressor. 10 mins later back moving. took the tire to DT and showed the guy where i plugged it. he made the comment they may not be able to repair plugged tires because the plug increases the diameter of the puncture. he also said the reamers damage the cords
i left the tire there and ask them to take a look and try to fix. they were able fix it . So was what he told me about fixing plugged tires correct?
Re: can't patch a plugged tire? [Re: WhyMe] #5220407 09/23/19 12:01 PM
B
BMWTurboDzl Offline
B
So he was going to remove the plug you added? Did you want him to add a patch to the plug? His explanation makes sense if you wanted him to remove the plug and then re-plug with a patch.
435i
Re: can't patch a plugged tire? [Re: WhyMe] #5220416 09/23/19 12:18 PM
Chris142 Offline
I never use the reamer.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: can't patch a plugged tire? [Re: WhyMe] #5220418 09/23/19 12:19 PM
F
FT92 Offline
F
years ago when I worked at a tire shop , there were plugs called a "plug patch" one unit, a combination plug and patch worked every time never had problems,, plug patch went in from the inside of the tire...this was 40 some years ago...maybe they don't have such a thing anymore
Re: can't patch a plugged tire? [Re: Chris142] #5220420 09/23/19 12:21 PM
Silverado12 Offline
If I don't ream out the hole I couldn't get the plug in. FWIW I have a Safety Seal kit with the reamer that supposedly dousn't damage the cords; it spreads them so you can get the plug into the hole. Disclaimer: my plugging experience is limited.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: can't patch a plugged tire? [Re: WhyMe] #5220423 09/23/19 12:22 PM
DBMaster Offline
I seem to recall seeing the guy at Discount Tire using a drill to enlarge the hole for the plug/patch. I wonder if that would be a good practice when trying to plug tires that have a hole too small to get a plug in.
Re: can't patch a plugged tire? [Re: BMWTurboDzl] #5220433 09/23/19 12:31 PM
W
WhyMe Offline OP
W
yes. i wanted him to remove the plug and then patch it. he was able to do it. Seems not too hard to remove a plug from the inside once the tire is off the rim.
Re: can't patch a plugged tire? [Re: FT92] #5220438 09/23/19 12:37 PM
BlueOvalFitter Offline
My uncle had those in his service station and tire store. We used them for large punctures.
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: can't patch a plugged tire? [Re: WhyMe] #5220440 09/23/19 12:42 PM
M
meep Offline
M
years ago Western Auto repaired a puncture my dad brought in. The rubber between the tread blocks looked to have been re-melted. It didn't bubble, I'm my assumption was this was also done on the interior.
Anyone seen this?
2018 F150
2015 crv (wifey!)
Re: can't patch a plugged tire? [Re: meep] #5220461 09/23/19 01:12 PM
L
Lolvoguy Offline
L
Anyone seen this?
Reminds me of a tire fix I had done on my Focus years ago.
Problem was the front tire had a nail in it, so I was losing air.
Shop told me since the tire affected is on the front, all I'd have to do is turn the wheels so the nail was exposed.
Once it was showing, he had some "goop" on something that looked like pipe cleaner attached to something with a "T" handle.
In one quick motion, the mechanic yanked out the nail with some pliers, then shoved the pipe cleaner goop into the hole.
He then proceeded to cut off the excess goopy thing, and all was well.
That was the fastest tire repair I'd ever seen.
Didn't even need to lift the car or remove the tire.
Never had a problem with that tire for the rest of the time I owned the car.
crzy
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: can't patch a plugged tire? [Re: meep] #5220465 09/23/19 01:14 PM
R
ragtoplvr Offline
R
That was a hot patch. Used to be very common. They were the best ever.
Now most shops will not patch at all. I have never had a sticky string fail. I do use glue with them, mostly as lubricant.
Rod
Re: can't patch a plugged tire? [Re: WhyMe] #5220477 09/23/19 01:29 PM
A
atikovi Offline
A
Re: can't patch a plugged tire? [Re: Lolvoguy] #5220518 09/23/19 02:05 PM
R
Rand Offline
R
crzy
that is a normal string plug and I use them(safety seal brand), but they are not as good as a patch-plug.
I have a safety seal kit another amazon lightning deal... I have used it 4x so far worked flawlessly.. although with one rear tire I had to remove the wheel from the car for clearance and leverage.
safety seal kit on amazon
Re: can't patch a plugged tire? [Re: WhyMe] #5220541 09/23/19 02:25 PM
I
InhalingBullets Offline
I
....most if not all of the major tire manufacturers recommend a plug and a patch for a proper repair.
https://www.tireindustry.org/tire-maintenance/tire-repair
'16 Toyota Prius 4
'15 Honda Accord Sport
'14 Victory Cross Country Tour
'13 Toyota Prius 3
Re: can't patch a plugged tire? [Re: InhalingBullets] #5220549 09/23/19 02:33 PM
A
atikovi Offline
A
Written by the tire industry, so of course they have no bias. LOL They want you to buy new tires instead of repairs and say to scrap tires with sidewall punctures. But... https://www.youtube.com/watch?v=riDyZs1bH7I
Page 1 of 4 1 2 3 4
