My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
121 registered members (ABN_CBT_ENGR, 830Lee, AandPDan, 2015_PSD, 2K2AcuraTL, 4WD, 7 invisible), 2,049 guests, and 53 spiders.
Topics306,007
Posts5,284,601
Members71,558
Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (7574 Miles) #5219981 09/22/19 07:46 PM
DuckRyder Offline OP
[Linked Image from rangerxlt.com]
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (7574 Miles) [Re: DuckRyder] #5220006 09/22/19 08:09 PM
A
addyguy Offline
A
For 7500 miles, I'd be happy with that.
2010 Kia Soul 2U - 2.0L I-4, auto; 153k miles.
Castrol GTX 5W-20; Motomaster MPH 9688
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (7574 Miles) [Re: DuckRyder] #5220064 09/22/19 09:51 PM
03cvpi Offline
The 3.7 has an internal water pump. Watch for a small coolant leak at the water pump leak hole. A you tube video will show you the exact location to watch for. If the internal water pump seal fails completely, it will dump coolant into the engine. Check under the intake manifold for a leak at the coolant crossover tube, those o-rings have been known to fail also.
Re: Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (7574 Miles) [Re: 03cvpi] #5220091 09/22/19 10:40 PM
Originally Posted by 03cvpi
The 3.7 has an internal water pump. ....
I meant to mention what the comment was about.
When I had an oil change they said that the degas bottle was “almost empty” and that there were no external leaks.
Shortly after I had enough down time to get it into a dealer at home and they determined it was holding pressure with a cooling system pressure test. They state (and alldata agrees) that it is a conventional water pump on this vehicle.
I’ll try to have a look at the crossover tube..
Robert
Re: Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (7574 Miles) [Re: DuckRyder] #5220252 09/23/19 08:03 AM
M
Miller88 Online Content
Online Content
M
What vehicle ?
The longitudinal ones have external water pump. Sideways ones have internal.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (7574 Miles) [Re: DuckRyder] #5220891 09/23/19 10:01 PM
03cvpi Offline
Sorry, I assumed from the mileage that it was one of the newer fords with a traverse mounted engine. In the standard online configuration, it would have an external mounted water pump. Also check by the coolant crossover by the rear of the engine.
