school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
109 registered members (ammolab, 1978elcamino, Al, 97prizm, 53' Stude, 13 invisible), 2,302 guests, and 22 spiders.
Topics301,661
Posts5,200,162
Members70,751
Haldex, Automatic on demand clutch fluid? #5219781 09/22/19 02:02 PM
sloinker Offline OP
I am going to be changing this fluid along with the filter on a 2016 VW Tiguan 4motion soon. I'm not finding much info about this fluid online other than it is pricey at $30 a quart. What makes it so special?
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Haldex, Automatic on demand clutch fluid? [Re: sloinker] #5219827 09/22/19 02:59 PM
L
Lowflyer Offline
L
Ravenol have now - as a single? - oil for Haldex. AWD-H. But, one for all Haldex types. VAG have at least 2 types. Hmm...
Maker of OEM is imho Pentosin. Developed in years with Haldex. Pentosin may not make aftermarket buisness with Haldex-oil.
Special on Haldexoil is... no one "outside" knows it. But it IS special. This will be evident if you make at changes your knockles dirty thereby.
Its feel like 0W-16, but you need 15min., 3 big cloths und 1gal brake cleaner wink to make your knockles clean again. I have never see such oil.
Not ATF, not MTF, not engine oil, not damper oil nor another oil. Lunacy.
You need only a one quart. Every ~30T miles. For me those 30 bucks (-> 30.000 miles) are dont most painful expenditure in car maintenance laugh
But 30$ for quart oil is very expensive. That's correct.
Re: Haldex, Automatic on demand clutch fluid? [Re: Lowflyer] #5219839 09/22/19 03:19 PM
sloinker Offline OP
Interesting Lowflyer. I used to work in the paper industry and they had these polymers that were beyond slippery and couldn't be washed off with soap and water or gasoline/brake cleaner etc. You get your hands wet a week later and they would still be slippery. Who knows the lasting impact of those chemicals once they hit your skin? I will probably order the OEM fluid from someone I suppose..
Found the SDS, doesn't look too crazy.
https://www.google.com/search?biw=1...CmseXkAhXGrJ4KHY9XDwwQ4dUDCAs&uact=5
Re: Haldex, Automatic on demand clutch fluid? [Re: sloinker] #5219947 09/22/19 06:18 PM
L
LotI Offline
L
I used Ravenol in my GTI e-diff, no difference from stock. In that app 1 bottle could do 3 changes as it only holds ~300mL.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX
Retired:
17 VW GTI
17 Mazda6 GT
14 Honda Accord Sport
Re: Haldex, Automatic on demand clutch fluid? [Re: sloinker] #5219960 09/22/19 06:28 PM
U
UG_Passat Offline
U
What makes it so special? VW packaging.
the G060 fluid is around $30, for 850 mL (or .89 quart).
You can also get the Febi-Bilstein stuff also, for less money.
Don't forget new drain plug and fill plugs.
And.. get yourself a general pump head, it's not going to fit the bottle of the OEM VW stuff (it's too large for the cap of the pump), but will still work if you're careful.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Haldex, Automatic on demand clutch fluid? [Re: sloinker] #5220156 09/23/19 03:29 AM
L
Lowflyer Offline
L
No one oil or grease I use in my S3 has officially approvals. Even my fuel is not standard.
The only with which I make never experiments are the Haldex-oil...
Re: Haldex, Automatic on demand clutch fluid? [Re: sloinker] #5330630 01/23/20 07:41 PM
E
E365 Offline
E
I’m about to change this fluid on my 17’ MINI Clubman ALL4. It has a 5th Gen Haldex system. Ravenol AWD-H ready to go in.
Newer VW and Volvos have the same system and the filter screen on the pump gets horrible clogged, sometimes under 30,000 miles. This newest system doesn’t have a removable filter, just the screen.
Some photos of badly clogged pump screens here:
https://www.vwroc.com/forums/topic/23536-mk7-haldex-fluid-change-and-pump-gauze-clean/
[Linked Image]
[Linked Image]
Whatever's on sale...
