littleant
Thread starter
Originally Posted by Warstud
Originally Posted by billt460
The answer was to insulate the walls, and replace the aging, non insulated wooden garage door with a metal insulated one.
Does the insulation keep the moisture out ? I was thinking maybe OP's problem was moisture from the garage floor.
I did read online that I can check if a moisture barrier was put in when the floor was poured. Placing a piece of plastic down. If the top of the plastic gets wet but not underneath then there is a moisture barrier. I will try that.
