Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Ghosty, zmann96, yetti96, weekendwally, Bugsbrewery
71601 Registered Users
115 registered members (aquariuscsm, 4WD, 1911CHAMPION, 14Accent, 830Lee, AlaskaMike, 14 invisible), 2,179 guests, and 65 spiders.
Topics306,100
Posts5,287,403
Members71,601
Winter tires for BMW X5 #5219763 09/22/19 02:42 PM
I
iExcel Offline OP
I
Hi folks,
My recently acquired 2018 BMW X5 seem to have summer tires on it as I don't see M+S label.
The tires right now are 20" and I am wondering if I could buy a new set of 19" rims and put on 19" winter tires. The 19" appears to be the standard tire size.
Will this be OK ? Thx.
2013 Volvo S80 FWD 3.2L I6
2018 BWM X5 xDrive 35i
Re: Winter tires for BMW X5 [Re: iExcel] #5219770 09/22/19 02:45 PM
Quattro Pete Offline
Yes, 19" will fit. Check tirerack.com for fitment details.
If it's the 35i, even 18" should fit.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Winter tires for BMW X5 [Re: iExcel] #5219810 09/22/19 03:34 PM
P
Pelican Offline
P
Originally Posted by iExcel
Hi folks,
As long as the overall diameter (wheel+tire) is the same, no problem.
Re: Winter tires for BMW X5 [Re: Quattro Pete] #5219832 09/22/19 04:04 PM
I
iExcel Offline OP
I
Yes. it's a 35i.
For winter driving, I care more about safety than appearance/performance. Would a 18" be safer than a 19" ?
Re: Winter tires for BMW X5 [Re: iExcel] #5219859 09/22/19 04:42 PM
I can't think of why one would be safer over the other.
I think the primary difference is that 18" winter tires will typically be less expensive with more options available. Going to 18" will give you slightly more tire sidewall as well - may or may not be important depending on how bad your local roads are.
Re: Winter tires for BMW X5 [Re: iExcel] #5219902 09/22/19 06:01 PM
K
krzyss Offline
K
Type of tire matching your road conditions is more important than size but smaller rims (and larger sidewall) provide cheaper solution to winter driving.
If you can go 20" => 18" than you may find that savings in tires pay for extra rims (which can be reused).
tirerack.com is good starting place.
Krzys
Re: Winter tires for BMW X5 [Re: iExcel] #5220041 09/22/19 09:12 PM
L
leeharvey418 Offline
L
The other big advantage of going with a smaller rim diameter is that you can get a narrower tire (which is generally preferred for winter) and still maintain the same load rating on your tires.
2014 Mazda CX-9 Touring AWD
2019 Mazda CX-5 Signature
Re: Winter tires for BMW X5 [Re: iExcel] #5220266 09/23/19 08:27 AM
edyvw Offline
Hi folks,
Is it square set up?
F15 X5 35i ca fit fallowing tires:
255/50 R19
255/55 R18
235/60 R18
235/60 R18 will be best option in deep snow. But car will be seriously "undertire." I had 255/55 R18 option on my X5 and proved for snowto be optimal option. In summer I used 255/50 R19. It is cheaper, a lot, and gives you more sidewall in case of slide, touching sidewalk etc.
Make sure you choose right tire. Suspension on X5 easily overwhelms tire so not all will do good. I had Bridgestone DM V-2 and proved mediocre in most situation (and pretty bad in lateral handling in ice). But, in dry and wet suspension proved to be more capable than tire. Michelin Xi2 I put later was far better option.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Winter tires for BMW X5 [Re: iExcel] #5220285 09/23/19 08:50 AM
B
Bjornviken Offline
B
Use 18" and tickest tire you can(xx/60+/R18)on the car and avoid m+s tyres if you have serious winters. Use real winter tires insted. Studded winter tires are the safest tires to use in winter time.
Re: Winter tires for BMW X5 [Re: Bjornviken] #5220403 09/23/19 11:58 AM
edyvw Offline
Again, 235/60 R18 has some serious dynamic limitations on that vehicle. Yes, narrowest tires are best in winter, but, there is a limit to that before other aspects are compromised.
Re: Winter tires for BMW X5 [Re: edyvw] #5220422 09/23/19 12:22 PM
B
Bjornviken Offline
B
ok, didn't know that
Re: Winter tires for BMW X5 [Re: Bjornviken] #5220504 09/23/19 01:52 PM
edyvw Offline
I was contemplating that size on my X5 until I tried it on friends X5. It seriously limits capabilities in any environment except deep snow.
Re: Winter tires for BMW X5 [Re: iExcel] #5220967 09/24/19 01:49 AM
02SE Offline
We used Pirelli Scorpion Ice and Snow runflats in the stock sizes on our X6 M last winter, even in the wide stock sizes (285/35R21 front and 325/30R21 rear) they did very well.
Re: Winter tires for BMW X5 [Re: 02SE] #5221780 09/24/19 11:50 PM
edyvw Offline
Pirelli always knew how to make winter tires.
