AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
78 registered members (ABN_CBT_ENGR, 4WD, Audios, Avery4, 2009Edge, 6 invisible), 2,211 guests, and 85 spiders.
Topics306,289
Posts5,289,675
Members71,618
Page 1 of 4 1 2 3 4
Sure you could use anti-seize on your studs, but??? #5219582 09/22/19 10:03 AM
T
Traction Offline OP
T
For everyone that thinks using anti-seize on wheel studs is a great idea, you might want to think about it more. Sure it will torque up and clamp the living do-do up really tight, but at the same time it is also can stretch the stud beyond the yield point to the point they could just snap. Yes sometimes a stud could use a touch of like WD-40 to free us a rusty stud, otherwise there is too much friction, and then the clamping force of the wheel can be to low. Dry, clean wheels studs, and a good torque wrench is the correct way.
Here are a couple of pages from my training manual, which has examples of the what the effect of putting lube on the studs, which can DOUBLE the clamping force, which turn into tons of force. Proper clamping force is the key to keeping the wheels attached to your vehicle.
Also, excessive clamping forces will probably distort, and damage the lug nut seats on the wheel, and brake rotor. And who knows what damage there is to the actual threads on the nut/stud.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219586 09/22/19 10:09 AM
J
jrvn Offline
J
whats clamping force?
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219589 09/22/19 10:14 AM
L
leeharvey418 Offline
L
I used to work in concrete testing, inspecting labs to make sure they were operating consistently. One of the inspection items was making sure the lab wasn’t using grease on the spherical seat of the compression test machine’s head. Oil will squeeze out of the joint under static load and the metal to metal contact will lock the head in place. Grease in the joint will never fully squeeze out, and the test specimen can kick violently out to the side when it starts to fail.
Any time I’m counting on friction to hold a joint together, I don’t want anything in the middle that could allow the connection to move.
2014 Mazda CX-9 Touring AWD
2019 Mazda CX-5 Signature
Re: Sure you could use anti-seize on your studs, but??? [Re: jrvn] #5219590 09/22/19 10:14 AM
L
L
It’s the thing that keeps your wheels from falling off.
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219612 09/22/19 10:36 AM
CT8 Online Content
Online Content
The advantage of anti seize is to seal the open parts of the threads.
2015 F150 2.7
2018 F350 6.2
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219623 09/22/19 10:52 AM
J
JeffKeryk Offline
J
I use a tiny bit of anti seize to avoid galling the threads. On spark plugs as well.
Of course I do clean the threads.
I understand there are reasons against this; this is just what I do.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219630 09/22/19 11:04 AM
R
Rand Offline
R
Right, this has been posted here about 180 times.
I still use a very small amount of boeshield-t9 on the threads none on the seat/head.. much better than replacing studs or spindles(lug bolts) in salt country.
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219638 09/22/19 11:23 AM
H
hallstevenson Online Content
Online Content
H
I posted in the other thread about Walmart doing this based on it being, apparently, their "corporate policy". If that's the case, you can be certain that they had a team of lawyers investigate this from a liability standpoint (no, I don't mean the lawyers got into mechanical calculations, etc, etc - they hire folks who deal with this stuff). If putting anti-seize on lug nuts is going to cause them to fall off and a wheel fall off, Walmart isn't going to go this route.
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219640 09/22/19 11:26 AM
M
maxdustington Offline
M
I don't think it's a 100% increase. I thought lubed threads got 15-20% less torque than dry?
100% seems like fasteners would be getting stipped like crazy, especially larger suspension fasteners that you almost have to anti sieze in the rustbelt and are likely to gun back on without a torque wrench.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219646 09/22/19 11:37 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Wheel studs are part of our business. We have actually run controlled studies trying to duplicate the damage seen in the field. Antiseize on the threads will not elongate and neck threads. We have seen damaged studs when people get happy with the antiseize and slather it on the nut mounting face as well as the threads, then torque to specification.
I also found automotive wheel studs don't neck until applied torque is around 4X specification.
For truck studs we specify two drops of oil on the threads before torquing to specification.
Re: Sure you could use anti-seize on your studs, but??? [Re: Rand] #5219649 09/22/19 11:40 AM
doitmyself Offline
LOL, probably more! I'm concerned about the effects of lube on torque as much as anybody else here with OCD. There is no consensus. How does Permatex get away with stating this on their anti seize tech sheet: "Reassemble parts using normal torque values." https://441py33rout1ptjxn2lupv31-wpengine.netdna-ssl.com/wp-content/uploads/tech_docs/tds/80208.pdf
I use it as others above do, knowledgeable of the possible effects if used incorrectly. Also, engineering sites state that torque wrench use has a +/- 30% error range and that fasteners are designed for this.
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219658 09/22/19 12:00 PM
T
Trav Offline
T
You have to take into account that the manufacturer may have published the spec with lubed threads. Most Euro car that use wheel bolts should have the threads and shoulder lubed (many U.S. owners manuals omit this for liability issues when some monkey lathers them up, anyone that has owned one in the salt belt that was installed dry knows why). There is no problem with a thin coat of never seize on lugs either, the wheel will not loosen and fall off, aluminum wheels should be retorqued after 100km always. From a FSM..
[Linked Image]
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219661 09/22/19 12:02 PM
T
Traction Offline OP
T
The thread title said "Sure you could use anti-seize". But everyone still seems to totally ignore the effect on wheel clamping force, which is going to over-stretch the wheel stud no matter how you justify it when using lube. If it make the nut easier to turn, it is going to turn much further before it comes up to the specified torque with the stud getting longer. How can that be the best practice, especially on cars that have quality plated studs, and lug nuts that still look new for years. Rusty, poorly maintained fasteners, all bets are off. Then it's always more of just a guess when using lube. I've torqued well over 50,000 lug nuts in the last 17 years, and have seen plenty of issues, and depending on the condition of the fastener, sometimes like on a German wheel bolt a little anti-seize is needed, but not every car needs it. It's mostly common sense.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Sure you could use anti-seize on your studs, but??? [Re: Traction] #5219664 09/22/19 12:09 PM
H
Online Content
H
You've stated your belief. Leave it at that and move on. 98% of folks are going to keep doing what they've been doing - "I've been doing it for 42 years with no issues". If you convince the other 2%, be happy.
Re: Sure you could use anti-seize on your studs, but??? [Re: hallstevenson] #5219672 09/22/19 12:17 PM
T
Traction Offline OP
T
Did you even read the charts at the top of the page? Maybe not an issue, but that still doesn't always make it right.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Page 1 of 4 1 2 3 4
