When I studied this stuff 2 years ago while installing a battery backup sump pump,
I found the literature to be inconsistent regarding charge and float voltages/amps for AGM batteries. It seems some of the highest quality AGM batteries for solar power require very specialized charging profiles. With more generic off the shelf AGMs (i.e., DEKA), the charge and float volts/amps seem to have optimum rates, but they overlap flooded battery requirements it seems.
GEL batteries seem the most different and require less charging voltage - 14v +/-.
Temperature seems to be more of a concern with AGM (and GEL) batteries due to their VRLA construction. For instance, a car alternator cranking out 14.8 volts in a high temp engine compartment might fry an AGM battery.
I guess my point is that while you guys talk about different charge/float voltage/amps of AGM vs. flooded, it does seem that they overlap enough so that various charges will work, but maybe not be optimized. Does that make sense?
I wonder if the chargers/maintainers mentioned above with no buttons to select gel/flooded/AGM just have one "in-between" profile to attempt to satisfy all?
This DEKA literature seems thorough about the subject:
http://www.eastpenn-deka.com/assets/base/0139.pdf ...Look at the temperature chart on page 11, which supports a temp compensated charger.
Also, this statement by Loti seems incorrect, especially the 13v float (too low): "Make sure your charger has a separate setting for AGM or flooded/gel batteries. Charge is well over 14V while float is closer to 13V." Gels seem best charged near 14V and flooded/AGM float charges seem to be between about 13.4 and 13.7 +/-, depending on mfg..
