Originally Posted by George7941
Doing it that way would mean that you lay the tint on the "wrong" side of the glass to get the right curvature. You would then transfer the tint over to the correct side of the glass and apply it after wetting. Do I have that right?
Correct, this is mostly done on rear windows. Heat form and final trim on the outside and then transfer to the inside for the install.
There are a few side windows that even have enough curve to them to make the installer want to heat form, new Beetle is the one that comes to mind, although there are probably more now. I haven't worked for him in forever, but I keep in touch and hang out at the shop from time to time, so I hear all the new car complaints.
