BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
93 registered members (4WD, Anduril, 14Accent, 77GrandPrix, ABN_CBT_ENGR, amblerman, 8 invisible), 2,092 guests, and 74 spiders.
Topics306,135
Posts5,288,105
Members71,604
Axle shaft seal leak? #5218860 09/21/19 01:14 PM
A
aquariuscsm Online Content OP
OP Online Content
A
I'v had this tiny leak for awhile now on my Accord (88,000 miles). I can't tell if it's coming from the case the axle shaft seal. The axle shaft seal was wet with fluid, and I'm wondering if it's leaking from there and running down to the bottom of the transmission case? In the picture you can see the oily trail coming from the seal down the side of the transmission case (although I wiped away most of it,it's still visible).
It's not severe enough that it drips onto the ground though. It's more of a weep than a leak. I'm sure the answer is "no",but do any additives exist that can be put into the transmission to condition the seal to stop the weeping that won't adversely affect the transmission?
[Linked Image]
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Axle shaft seal leak? [Re: aquariuscsm] #5218952 09/21/19 03:40 PM
CT8 Offline
Get some brake cleaner and clean the areas all the up to the top of the engine and then look for the leak.
2015 F150 2.7
2018 F350 6.2
Re: Axle shaft seal leak? [Re: aquariuscsm] #5219038 09/21/19 05:09 PM
E
eljefino Offline
E
Seals weep to work. If your fluid level stays put I'd let it be.
