Happy Birthday, "Wierd Al" Yankovic!
by eljefino - 10/23/19 03:49 PM
Havoline ProDS Syn 10W-30 $19.73 6-pack
by Jackson_Slugger - 10/23/19 03:02 PM
Wix Oil Filter Rating Question
by 02vito - 10/23/19 02:30 PM
Help me decide between Fram and Mobil 1
by ZiTS - 10/23/19 02:13 PM
2003 BMW E46 M3 Rotella 15w40
by Manners226 - 10/23/19 02:10 PM
Firearm solvent/oils
by HyundaiAbuser - 10/23/19 01:56 PM
Coloured wax
by Propflux01 - 10/23/19 01:36 PM
Elk Jerky
by 28oz - 10/23/19 01:15 PM
If idle is to be avoided?
by Rglossip - 10/23/19 01:01 PM
Beck Arnley Brake Pads FMSI Materials?
by jrvn - 10/23/19 12:39 PM
Aging - What the ....
by coopns - 10/23/19 12:13 PM
Chevron Supreme 5W20 Bay Area Trade/Sell
by e55amgbenz007 - 10/23/19 10:07 AM
Auto Extra 51348 Vs Napa Gold 1348
by BeerCan - 10/23/19 10:05 AM
Latest Scam Method?
by 2015_PSD - 10/23/19 09:47 AM
Medical bills from 3 year back
by stockrex - 10/23/19 09:31 AM
2019 Nissan Pathfinder CVT drain/fill.
by JTK - 10/23/19 09:19 AM
Do I need Intel RST?
by Quattro Pete - 10/23/19 08:50 AM
Anabond 230 for bonding brake linings
by sdowney717 - 10/23/19 07:29 AM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
89 registered members (AndyB, Ag76, 2015_PSD, 02vito, 4WD, 7 invisible), 2,210 guests, and 27 spiders.
Topics296,392
Posts5,096,817
Members69,652
Most Online3,532
Jul 30th, 2019
What make steering wheel hard to turn #5218829 09/21/19 12:43 PM
R
Rohan Offline OP
R
After driving for 35 minutes then turning the wheel in the parking lot. It because hard to turn right. My power steering fluid is at the right level. Belt been changed also. This is for 2011 mercede e350 rwd
Re: What make steering wheel hard to turn [Re: Rohan] #5218837 09/21/19 12:50 PM
M
mclasser Offline
M
Possible failing pump or rack & pinion.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: What make steering wheel hard to turn [Re: Rohan] #5218838 09/21/19 12:51 PM
L
LotI Offline
L
Can’t be the pump if it’s easy effort to the left. Most likely steering rack or possibly a ball joint
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: What make steering wheel hard to turn [Re: Rohan] #5218841 09/21/19 12:53 PM
CT8 Offline
Jack the front end off the ground and see how the steering feels then go from there before throwing parts at the car.
2015 F150 2.7
2018 F350 6.2
Re: What make steering wheel hard to turn [Re: Rohan] #5218862 09/21/19 01:16 PM
W
Wolf359 Online Content
Online Content
W
Double check your fluid level. Mine used to do that too, but it was a little bit low. Added a little fluid and it all went away. Racks also go bad, but it's very rare. Also I've changed the belt, tensioner and the two idler pulleys, they're also well known to go. There's usually some play in all three of those.
Re: What make steering wheel hard to turn [Re: Rohan] #5218911 09/21/19 02:54 PM
W
Warstud Offline
W
Power steering is the most neglected fluid on a vehicle. Try changing the fluid.
Re: What make steering wheel hard to turn [Re: Rohan] #5218920 09/21/19 03:08 PM
O
oldhp Offline
O
Isn't there a shuttle valve in the rack that diverts fluid one way or the other??? Easy one way but hard the other way??? IDK???
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: What make steering wheel hard to turn [Re: Warstud] #5219015 09/21/19 04:40 PM
J
JLTD Offline
J
This.
I use the overseas manual to choose my viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: What make steering wheel hard to turn [Re: Rohan] #5219057 09/21/19 05:39 PM
9
92saturnsl2 Offline
9
I've had racks go bad in two cars I've owned over the last 10-15 years. Both presented the same symptom-- random "tightness" or resistance to turning that came on suddenly. It was not repeatable; if you let up on the steering (or bumped the wheel the other way) then pushed in the desired direction once again, it would usually cooperate.. I can't recall if it was problematic turning only one direction, but it made for interesting driving when your steering wheel freezes up in the middle of a turn!
Does your Mercedes require a special fluid, and if so, has that fluid been used religiously with no top-up of regular fluid? That's how the rack in my VW got torched, I used regular Autozone power steering fluid for top-up instead of the uber-expensive synthetic German fluorescent green Pentosin stuff I was supposed to use. Turned all the fluid into a tan milkshake color and trashed the rack. After a flush I was still able to drive it but the problem never went away until I replaced the rack.
96 Grand Prix SE (project car)
04 Odyssey EX 200k Philips Shield Choice 10w-30
96 Maxima GLE 275k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 145k Castrol Edge 0w-30 Euro
Re: What make steering wheel hard to turn [Re: CT8] #5219265 09/21/19 09:47 PM
Dinoburner Offline
Yup this is the best place to start.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: What make steering wheel hard to turn [Re: Rohan] #5219325 09/21/19 11:14 PM
R
Rohan Offline OP
R
Power steering (pentosin)fluid was changed along with reservoir, power steering cap, and changed the belt, tensioner and the two idler pulleys all of them last year. The only issues I have is both of the wheels bearings is going out on the front end , also has crack wheel on right front side that causing loose air while driving down the road so I have to fill it up before it get to low.
Re: What make steering wheel hard to turn [Re: oldhp] #5219326 09/21/19 11:15 PM
R
Rohan Offline OP
R
Are you talking about this? If so I did checked that out on mbdata for my car and was not equipped with this car.
https://www.eeuroparts.com/blog/10233/mercedes-benz-speed-sensitive-steering/
