Forums Migration
Please read this thread
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
122 registered members (2004tdigls, Aichiguy, 2K2AcuraTL, 2015_PSD, aleneros, 2010Civic, 11 invisible), 2,145 guests, and 27 spiders.
Topics307,575
Posts5,313,359
Members71,876
TCW3 fuel mix #5218738 09/21/19 10:44 AM
O
otis24 Offline OP
O
I have about 14 gallons of fuel in my boat, mixed at a 50:1 ratio. I had planned to run it out, but weather may prevent me from getting the boat out again. I would like to run the fuel in my vehicles. How many gallons of fuel should I run with a gallon of boat fuel?
I was thinking one or two gallons in a 20 gallon tank.
1991 Chevrolet K1500 (4.3, 4x4, 86k miles)
2016 Dodge Grand Caravan
(3.6 V6) 46500 miles
Re: TCW3 fuel mix [Re: otis24] #5218762 09/21/19 11:10 AM
K
Kira Offline
K
First off, I don't know what TCW3 fuel mix is. A 2-cycle oil and stabilizer combo?
Your mix ratio (50:1) means there are 2.56 oz of product added to each gallon of gas.
If you add one gallon of your mix to 19 gallons of fresh fuel you'll have 2.56 oz. of product to 2,560 oz. of fuel.
The resulting mix will be 1,000:1. You can't just ignore round numbers.
Who cares if you foul your plugs or injectors? You gotta go with that WINNING math!
SERIOUSLY: You can't give mix away because if you do and your friend's boat misfires or fails to start 3 seasons from now, they'll still come and blame you.
Ask me how I know.
Re: TCW3 fuel mix [Re: otis24] #5218764 09/21/19 11:12 AM
Rat407 Offline
That will work just fine with no issue. You can even run it in your lawnmower if you want.
2002 Silverado 5.3 5w-20 AMSOIL
Re: TCW3 fuel mix [Re: Kira] #5218769 09/21/19 11:19 AM
O
otis24 Offline OP
O
Ask me how I know.
Many on BITOG use a mix of 1 oz TCW3 (two cycle water cooled) oil per 5 gallons of gas as a cleaner for injectors and valves.
Re: TCW3 fuel mix [Re: otis24] #5218780 09/21/19 11:33 AM
K
Kira Offline
K
There you go!
So dumping a gallon of your mix into a 20 gallon tank before filling up will present no problem. Might even help a tad.
As you can tell, I'm no kind of "additive guy".
5 or 6 years ago my friend's son mentioned Sea-Foam to me and I had no idea what the stuff was and he looked at me like I had 2 heads.
Now I WANT to try it! Sucking the stuff through a brake booster pipe is intriguing.
Re: TCW3 fuel mix [Re: otis24] #5218846 09/21/19 12:58 PM
CT8 Offline
In the pick up I would run 5 gallons the first fill up the 2 or 3 after that to be conservative. at each fill up. 20+ gallon tank
2015 F150 2.7
2018 F350 6.2
Re: TCW3 fuel mix [Re: CT8] #5218850 09/21/19 01:03 PM
PimTac Offline
Five gallons of oil????
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: TCW3 fuel mix [Re: otis24] #5218857 09/21/19 01:07 PM
PimTac Offline
2017 Mazda CX5
Roki OEM filter.
Re: TCW3 fuel mix [Re: PimTac] #5218955 09/21/19 03:42 PM
CT8 Offline
Did you read the post?
2015 F150 2.7
2018 F350 6.2
Re: TCW3 fuel mix [Re: otis24] #5218999 09/21/19 04:26 PM
J
JLawrence08648 Offline
J
I'm always concerned with the computerized systems in cars how it will affect the computer mixing and changing the air fuel ratio as you drive to compensate for the enriched fuel mixture. ?????
I use good old gas in my car and good 2 cycle mix in my lawnmower and snowblower. It is my belief, adding a little 2 cycle oil to 4 cycle equipment extends the piston, rings, and cylinder life because it provides upper cylinder lubrication.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: TCW3 fuel mix [Re: CT8] #5219084 09/21/19 06:30 PM
B
BrocLuno Offline
B
+1 smile
Re: TCW3 fuel mix [Re: otis24] #5221436 09/24/19 03:16 PM
H
hatt Offline
H
Dump in a gallon of mix for each 12 gallons or so of fresh fill.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: TCW3 fuel mix [Re: otis24] #5224810 09/28/19 02:22 PM
J
jahwarrior1423 Offline
J
Im interested in this. Dont see a ton of into about it, though.
Re: TCW3 fuel mix [Re: otis24] #5245638 10/21/19 07:11 AM
J
JimGA Offline
J
I certainly would not worry about running some premix in a modern car or truck.
I have been running it in my 2017 Toyota Sienna for about 50K miles at roughly a 200-1 ratio of oil to mid grade gas.
why? it's direct injected, and I want a little lube for the high pressure fuel pump. If I'm on the road and have no oil, then I don't worry about it.
The octane of the 2 stroke oil could be as low as 50-60 octane from what I have been able to find out and I'm not certain of even that number.* At a 200-1 ratio, this will lower the octane of the fuel about .2 of a point. So my midgrade becomes 88.8 instead of 89
That is the only possible down side to using it that I can see.
You will NOT have carbon build up, smoke from the tail pipe or fouled plugs. That is thrown out in every thread, but no evidence to back it up.
*I got the 50-60 octane number from an article that said a 50-1 ratio would drop the octane about 1 point. I know regular motor oil can be as low as 20-30 octane, but they are not designed to burn as fuel.
Re: TCW3 fuel mix [Re: otis24] #5246049 10/21/19 01:57 PM
DGXR Offline
I would run 1 gallon of your boat gas to 8-10 gallons of straight unleaded. TCW3 won't hurt cats or anything else at this ratio. Might actually help clean up a few things.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
