Forums Migration
Please read this thread
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
103 registered members (2003f7, AlienBug, Alaskanmont, 2004tdigls, 2015_PSD, Aichiguy, 9 invisible), 2,073 guests, and 22 spiders.
Topics307,575
Posts5,313,373
Members71,876
Quart bottle cap #5218392 09/20/19 11:11 PM
M
maverickfhs Offline OP
M
So I have a strange question, what would be the capacity or size of engine oil quart cap? If it's full completely.
Like if I pour into it, is it like 0.5 oz roughly? Too lazy to check and thought some expert might already know it smile
Thanks much.
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Quart bottle cap [Re: maverickfhs] #5218402 09/20/19 11:24 PM
K
Kruse Offline
K
There are different size caps depending on the container.
Re: Quart bottle cap [Re: maverickfhs] #5218404 09/20/19 11:29 PM
M
M
It's the one on a 7-11 tcw3 quart bottle smile
Re: Quart bottle cap [Re: maverickfhs] #5218493 09/21/19 05:28 AM
M
MParr Offline
M
Measure it. Certainly you have some measuring spoons.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: Quart bottle cap [Re: maverickfhs] #5218509 09/21/19 06:07 AM
K
krismoriah72 Offline
K
Thanks much.
Probably more like 1/3 that. With your math about 64 caps full would fill another quart bottle.
If you are adding to a car the ratio is 1oz to 5gal.
Next time you try it buy a bottle with a clear strip on the side with increments then keep the bottle.
Re: Quart bottle cap [Re: maverickfhs] #5218520 09/21/19 06:19 AM
blupupher Offline
not enough to make any difference in an engine.
'18 Santa Fe: PP 10w-30/OEM
'18 Soul: Delo 400 10w-30/ST
'12 xB: M1 EP 0w-20/CQ Blue
'10 Santa Fe: Pento HP 5W-30/TG
'04 F150: Delo 400 10w-30/ST
'02 F150: PP 0w-20/M1
'94 GL1500: Honda 10w-40/OEM
Re: Quart bottle cap [Re: maverickfhs] #5218530 09/21/19 06:32 AM
M
M
I am adding it in a motorcycle gas tank of 5 gallons.
Re: Quart bottle cap [Re: maverickfhs] #5218533 09/21/19 06:36 AM
A
ARCOgraphite Offline
A
Anti Rust?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Quart bottle cap [Re: maverickfhs] #5218534 09/21/19 06:36 AM
M
M
No it's a carbed one.
Re: Quart bottle cap [Re: maverickfhs] #5218539 09/21/19 06:40 AM
A
A
I top oil all my ODPE but the only MC I top oiled was my Suzuki T350 Rebel
[Linked Image]
Re: Quart bottle cap [Re: maverickfhs] #5218561 09/21/19 07:06 AM
K
Kira Offline
K
Talk about putting the cart before the horse!
How is the product's recommended dosage stated on the container?
Have you calculated how much volume you want to add to your 5 gallons of fuel?
FYI: 128 fl. ounces = 1 U.S. gallon. Your tank holds 640 ounces.
Is asking you to cut the cryptic nonsense (and ask your question straight) too harsh a thing to do?
TO Argographite: I'd love to hear about "top oiling". Is that what some MMO people do?
Re: Quart bottle cap [Re: maverickfhs] #5218563 09/21/19 07:12 AM
M
M
640:1 planning to use, need 1floz for a ~5 gallon tank.
Re: Quart bottle cap [Re: maverickfhs] #5218617 09/21/19 08:30 AM
E
eljefino Offline
E
A fluid oz is a shot glass.
Re: Quart bottle cap [Re: maverickfhs] #5218774 09/21/19 11:25 AM
K
Kira Offline
K
The first definition of "shot glass" I found said it was 1.5 ounces! I always thought 1.5 oz. was a jigger.....so I looked that up too.
They said jigger was 1.5 oz. Get a break-proof container and calibrate it yourself SO YOU KNOW.
Our neighbor had a fuel cap on an old tractor which included a measuring cup built in.....all one piece
With the cap on tight the cup pointed down into the fuel tank. Something like that would fit your needs perfectly.
Re: Quart bottle cap [Re: Kira] #5218788 09/21/19 11:39 AM
Quattro Pete Offline
Capacity of a shot glass seems to vary, depending on whom you ask. Anything from 1 to 1.5 oz can be considered a shot.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
