Happy Birthday, "Wierd Al" Yankovic!
by eljefino - 10/23/19 03:49 PM
Havoline ProDS Syn 10W-30 $19.73 6-pack
by Jackson_Slugger - 10/23/19 03:02 PM
Wix Oil Filter Rating Question
by 02vito - 10/23/19 02:30 PM
Help me decide between Fram and Mobil 1
by ZiTS - 10/23/19 02:13 PM
2003 BMW E46 M3 Rotella 15w40
by Manners226 - 10/23/19 02:10 PM
Firearm solvent/oils
by HyundaiAbuser - 10/23/19 01:56 PM
Coloured wax
by Propflux01 - 10/23/19 01:36 PM
Elk Jerky
by 28oz - 10/23/19 01:15 PM
If idle is to be avoided?
by Rglossip - 10/23/19 01:01 PM
Beck Arnley Brake Pads FMSI Materials?
by jrvn - 10/23/19 12:39 PM
Aging - What the ....
by coopns - 10/23/19 12:13 PM
Chevron Supreme 5W20 Bay Area Trade/Sell
by e55amgbenz007 - 10/23/19 10:07 AM
Auto Extra 51348 Vs Napa Gold 1348
by BeerCan - 10/23/19 10:05 AM
Latest Scam Method?
by 2015_PSD - 10/23/19 09:47 AM
Medical bills from 3 year back
by stockrex - 10/23/19 09:31 AM
2019 Nissan Pathfinder CVT drain/fill.
by JTK - 10/23/19 09:19 AM
Do I need Intel RST?
by Quattro Pete - 10/23/19 08:50 AM
Anabond 230 for bonding brake linings
by sdowney717 - 10/23/19 07:29 AM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
88 registered members (AndyB, Ag76, Auae85, 2015_PSD, 02vito, 7 invisible), 2,195 guests, and 27 spiders.
Topics296,392
Posts5,096,817
Members69,652
Most Online3,532
Jul 30th, 2019
2000 Honda CR-V Ex transmission fluid? #5218159 09/20/19 05:36 PM
T
taztheman Offline OP
T
I am a new Honda owner and want to change the transmission fluid on my automatic transmission. The manual calls for oem Honda fluid but it is not in any parts store or dealership nearby. Is it important to use Honda oem fluid, if not what is an alternative?
Re: 2000 Honda CR-V Ex transmission fluid? [Re: taztheman] #5218190 09/20/19 06:21 PM
2
2010Civic Offline
2
Order it online. I've bought it on ebay for less than the dealership.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: 2000 Honda CR-V Ex transmission fluid? [Re: taztheman] #5218209 09/20/19 06:45 PM
G
Gebo Offline
G
I would only use Honda fluid. You must really live out in the sticks if there are no Honda Dealerships around smile
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Supertech Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 2000 Honda CR-V Ex transmission fluid? [Re: taztheman] #5218211 09/20/19 06:49 PM
Chris Meutsch Online Content
Online Content
You can buy it on Amazon.
2005 Honda CR-V EX, 276k
Re: 2000 Honda CR-V Ex transmission fluid? [Re: taztheman] #5218224 09/20/19 07:01 PM
ctechbob Offline
You can get it on Amazon or Ebay by the case for decent money. There are also plenty of people that use Valvoline Maxlife with good results, or one of the other DW1 'replacements' (Idemitsu/Aisin/Etc)
2008 Acura TL Type S-155k*
2003 Honda Accord V6-207k
Oil-Havoline ProDS 5W30 / *HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: 2000 Honda CR-V Ex transmission fluid? [Re: taztheman] #5218226 09/20/19 07:02 PM
slacktide_bitog Offline
Castrol Full Synthetic ATF is awesome and will work well in your CRV smile
Another good choice is Maxlife
Re: 2000 Honda CR-V Ex transmission fluid? [Re: taztheman] #5218237 09/20/19 07:12 PM
J
JeffKeryk Offline
J
I have used Honda fluid, Maxlife, Castrol and Idemitsu Honda spec.
All good. Idemitsu is my favorite.
If it has never bee done, do a few spill and fills.
Your CR-V will thank you. You will feel the difference; it will be smoother and pull better.
Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2000 Honda CR-V Ex transmission fluid? [Re: taztheman] #5218315 09/20/19 09:00 PM
Surfdog4 Offline
I used Maxlife on a 2000 Odyssey and 2002 CR-V for many years. Works great, readily available and good price.
2018 Chevrolet Traverse
2016 Subaru Outback
1990 Porsche 911 Carrera 2
Re: 2000 Honda CR-V Ex transmission fluid? [Re: JeffKeryk] #5218316 09/20/19 09:02 PM
T
T
If I am only changing the fluid with Valvoline maxlife will it be ok to do 1 or 2 changes? The reason I am asking is because I assume the fluid in the transmission is oem honda fluid, but it is not to dirty. I am just changing the fluid for preventive maintenance.
Re: 2000 Honda CR-V Ex transmission fluid? [Re: taztheman] #5218324 09/20/19 09:16 PM
Surfdog4 Offline
each time you change it you are getting half the fluid out, so its basically youre call as to how much is enough. They should mix fine.
Also, im not sure about the 2000 but on 2002 changing that rear diff fluid was almost more important. A few years ago that was a honda-only fluid
2016 Subaru Outback
Re: 2000 Honda CR-V Ex transmission fluid? [Re: Surfdog4] #5218355 09/20/19 10:10 PM
ctechbob Offline
The 'official' Honda method is 3x drain/fill with a short drive in between. If you're sure its never been done, it would be a good idea to get as much of the old out as possible. I would at least do it 2x and then perhaps another time at the next oil change.
Trans-Idemitsu H+
Re: 2000 Honda CR-V Ex transmission fluid? [Re: taztheman] #5220209 09/23/19 06:45 AM
B
berniedd Offline
B
In my CRV, I've used Castrol MultiVehicle, Mobil1 and Mag1 Fully Synthetic ATF, with good results. Use the same fluid for the rear differential if yours has the Realtime AllWheel Drive.
