Aircraft Tempest Spin-EZ AA-48108-2
Stuart, Fl
-40 hr interval Mooney M20k Continental TSIO-360-LB
-Aeroshell w100 out & in
-torn valve
-Magnet in second to last photo
-Last photo shows Aeroshell label recommending retest after 4 years from manufacture date...
No oil on gasket and use safety wire. Interesting.
The torn ADBV is sad, but overall the media looks good. The engine looks clean too.
The gaskets are pre-lubricated but I wonder what are the dangers of using DC4?
Thanks.
This is a magnet? Looks pretty clean
UD
[Linked Image]
Yes uncle, that's the magnet, it was very clean. I didn't bother to cut the pleats out as I am saving for the mechanics coming annual inspection (only a few small non metallic particles can be seen peeking in-between pleats). This is the cleanest & best looking filter/oil change since recent top overhaul. I'm thinking about going 50 hrs with mechanics approval
If you wiped that magnet with a clean white paper towel you'd probably get a bit of "black goo" off of it.
