So got tired of playing games with the Primewell tires on the RV so had the rear tires changed out with Dueler LTH at Discount Tire (expensive but tired of playing with vibrations!). Should of did all six since after fixing the rear I could feel the fronts vibrating. Kinda short on time and Discount didn't have anymore in stock so I had Zohr tire do the fronts. Didn't pay attention fully setting up the order as all they had was the HT's. Tread's a little different but load rating is the same. I was curious so tried to research the difference of the two and can't find the LTH on Bridgestone's website. Anyone with insight on what these two? Not really concerned just curious.
On a side note have to go back to discount as they didn't put any valve caps on and not one tire was the same pressure OR the pressure I requested. Can't trust anyone anymore it seems. Now Zohr tire did exactly what I asked, the verdict is still out as they had to use more weight that then rears. What's good about Zohr is they come to you and do everything in your driveway. Hopefully all is well and I'll use them from now on.
