Jay Leno-- Honda 50/Cub Memories
by csandste - 01/29/20 02:47 AM
JWS 3009 vs Dex III - AW55-50
by Bailes1992 - 01/29/20 02:26 AM
Virgin FL820S Cut Open
by TXCarGeek - 01/29/20 01:04 AM
2006 Caravan... how to remove window Regulator
by DeafBrad - 01/28/20 11:10 PM
Ford oil spec for 2015 F150 w/ 2.7L EcoBoost?
by RonRonnster - 01/28/20 09:51 PM
Fun spark plug discussion
by 14Accent - 01/28/20 09:12 PM
Camry vrs Sonata
by tblt44 - 01/28/20 07:50 PM
Parasitic battery draw.
by wtd - 01/28/20 07:49 PM
AAP clearance 2020
by GMguy84 - 01/28/20 07:34 PM
2017-2019 GLA 250 4-Matic vs BMW X-1
by HangFire - 01/28/20 07:20 PM
Good news for .300blk shooters
by The_Eric - 01/28/20 06:43 PM
‘16 Lexus GS350 vs ‘16 Lexus RX350
by miden851 - 01/28/20 06:19 PM
Stone guard removal
by dawgn86 - 01/28/20 06:09 PM
Craigslist is like a petty HOA now
by eljefino - 01/28/20 05:06 PM
Shoretel PABX - any experience?
by stockrex - 01/28/20 04:44 PM
Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
indigo2020, Towkid, denor, Jubaxtreme, CAJ1966
70551 Registered Users
31 registered members (antone, 330indy, bbhero, berlinbai, DaleRider, 4 invisible), 1,198 guests, and 17 spiders.
Topics300,689
Posts5,181,194
Members70,551
Fleetguard LF777 performance #5216610 09/18/19 09:54 PM
P
Pyrotechnic Offline OP
P
Ive found various forum conversations about this filter, and at some point the micron rating comes up, and someone will post some really awful micron number allegedly from Fleetguard and then the discussion ends. It seems to get written off as an old design not worth anyone's time. From what I understand it came out around 1980 to replace the huge LF500 bypass units that were filled with newspaper and wood chips.
Looking at a Fleetguard catalog, I see the LF777 mentioned as 5 micron, but no beta ratio. The Fleetguard LF777 is made with stacked disc media, the same kind found in the Venturi series of filters. I have a hard time believing that the 777 is a poor performer, if it is full of the same media that makes the Venturi filters so great.
Does anyone have any personal experience with the LF777 and how well it performs?
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5216775 09/19/19 06:19 AM
B
bullwinkle Offline
B
I have experience with the stacked disc Venturi filters, and they do a really good job keeping diesel oil visibly cleaner-but it will take before & after particle counts to tell what the actual difference is.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5261145 11/07/19 07:20 PM
J
jetman Offline
J
In 2011 I was building and installing bypass filtration systems on Cummins M11 and ISM engines. I got in a discussion on a forum about what would be the best spin-on bypass filter to use on the remote mount I was using. A Cummins/Fleetguard Field Service Engineer on a forum said the LF777 was the best. A phone call to their tech dept told me the LF3542 was better. The Field guy said the LF777 is a stacked disc design and was 98% efficient at 10 microns. He also told me the LF3542 was 99% efficient at 10 microns. Both are about the same physical size and cost about the same. The threads on both are 1 3/8" x 16. I ended using the LF3542. These days I just install Fleetguard Venturi Combo filters. They do the jobs of both a full flow and bypass filters.
Venturi Combo link
Fulltime DIYer, retired pilot
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
96 Prevost XL40 12.7
51 Chevy 5w PU Resto 5.3
92 TopSportsman Firebird w/604
241" 4link Dragster w/565
83 Glasair! TD
90 Ez-Go 2-cysle GC
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5262997 11/10/19 04:06 AM
CDX825 Offline
Ive always wondered the same thing about the LF777 filter. I figure that stacked disc media has to do better than the pleated style of bypass filter.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: Fleetguard LF777 performance [Re: CDX825] #5263122 11/10/19 08:22 AM
J
jetman Offline
J
If I was doing it today, I would us the LF777.
It would be interesting to cut each open to see what is what.
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
83 Glasair! TD
90 Ez-Go 2-cysle GC
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5266866 11/14/19 09:33 AM
L
Linctex Offline
L
I have the same base, but use a Wix 51749 .... just because they are so darn cheap!
Re: Fleetguard LF777 performance [Re: Linctex] #5275438 11/23/19 12:35 PM
P
P
Have you opened one of these up or looked down the center hole? Do they have stacked disc media or pleated paper? I've heard that some of the LF777 crosses have a regular pleated paper element inside.
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5275837 11/23/19 10:12 PM
J
jetman Offline
J
Here are the specs for:
Fleetguard LF777 = 99% @ 30 microns: LF777 link
Fleetguard LF3542 = 100% @ 30 microns: LF3542 link
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
83 Glasair! TD
90 Ez-Go 2-cysle GC
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5276011 11/24/19 07:32 AM
J
jetman Offline
J
Bad link for LF777?
Here it is again: LF777 link
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
83 Glasair! TD
90 Ez-Go 2-cysle GC
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5293680 12/13/19 05:26 PM
L
Linctex Offline
L
I will be very soon.
I'm 99.999% sure it's the same 5-micron pleated paper as the WIX fuel filters use.
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5300124 12/20/19 04:18 PM
P
P
Fleetguard seems to list many oil filters on the website, both full flow and bypass, with the same 99% @ 30 or 100% @ 30 rating. It seems to be nothing more than a default value or a placeholder.
Here's a screenshot from a 2012 Fleetguard catalog. It is an installation diagram for an oil level regulator system, showing an LF777 as an optional 5 micron filter.
[Linked Image]
Then there's this post I found with communication from Fleetguard, with the LF777 being "10 Micron at 98% efficient and 5 Micron at 95% efficient."
https://www.bobistheoilguy.com/foru...in-b-164-a-good-bypass-filter#Post857926
Lots of conflicting information, but in my opinion I think that a genuine Fleetguard LF777 would be worth a try, based on the design and the more favorable numbers that Fleetguard has published.
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5320374 01/11/20 11:32 PM
J
jetman Offline
J
It's not conflicting info. A filters efficiency % decreases as the micron size gets smaller. That's how it works.
100% at 30 microns
98% at 10 microns
95% at 5 microns
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
83 Glasair! TD
90 Ez-Go 2-cysle GC
