Forums Migration
Please read this thread
What is this charger for?
by CharlieJ - 07/10/20 05:58 PM
World War II movie Greyhound
by skyactiv - 07/10/20 05:48 PM
GC for Fuel Dilution - Accuracy
by Gene K - 07/10/20 05:21 PM
How Do I Get This On?
by Gebo - 07/10/20 05:08 PM
Creativity Suggestions?
by maverickfhs - 07/10/20 03:18 PM
3.5 Ecoboost Oil, I've decided.
by Gene K - 07/10/20 02:07 PM
Mopar Extended Warranty with 100% Refund Option
by The Critic - 07/10/20 12:46 PM
The great lakes are warm!
by OVERKILL - 07/10/20 11:38 AM
OSX 10.15.5 Mail Program POP Issue
by JHZR2 - 07/10/20 10:51 AM
Slightly used Hyundais's and Kia's for sale...
by mattwithcats - 07/10/20 10:38 AM
Best power steering fluid to quiet fussy pump
by dfarr67 - 07/10/20 10:30 AM
Triple QX 5W40 Oil.
by SpitFire6 - 07/10/20 09:46 AM
626,000 mile Pentastar teardown
by wwillson - 07/10/20 08:25 AM
Price components of gasoline and diesel
by Snagglefoot - 07/10/20 08:20 AM
Peak Synthetic
by oilchangeguy - 07/10/20 07:01 AM
[Cut Open] FRAM Ultra XG7317 (6230 miles)
by DuckRyder - 07/10/20 06:41 AM
Need a New Frig
by Boomer - 07/10/20 06:01 AM
SUmeme22, DaveCaddell, SharkNC, Puckster02, TurbodogTodd
71907 Registered Users
87 registered members (2015_PSD, another Todd, AnthemBassMan, aigochamaloh, afree, AlienBug, 11 invisible), 1,852 guests, and 44 spiders.
Topics307,692
Posts5,315,933
Members71,907
Any Vacuum experts? :) #5216591 09/18/19 09:50 PM
M
maverickfhs Offline OP
M
I have a DC18 Dyson vacuum, where motor overheats and it shuts down after a few mins(4-5mins).
It doesn't happen immediately, brush rolls and its sound changes like it's about to die and then it'll shut off.
Cleaned all the wand, pipes, lower brush area and all filters. If I remove the whole cyclone and filter body, then turn it on there's a lot of suction on the hole which goes into the cyclone. While running, wand has very minimum suction.
I feel like, there's some blocking, maybe in the lower ball area, is there a way I can validate it? Thank you for the advise and help.
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Any Vacuum experts? :) [Re: maverickfhs] #5216602 09/18/19 10:28 PM
dishdude Online Content
Online Content
Vacuums suck.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Any Vacuum experts? :) [Re: maverickfhs] #5216608 09/18/19 10:48 PM
T
tomcat27 Offline
T
is there any chance that the cooling slots for the motor itself are clogged with debris
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Any Vacuum experts? :) [Re: maverickfhs] #5216711 09/19/19 05:53 AM
I
Imp4 Offline
I
You can take the lower ball area apart for better access.
Fish a coat hanger all the way up the articulating hose from the brush to the connection.
Also fish one all the way through the clear hose on the back of the unit.
A small plastic obstruction is nearly undetectable otherwise.
Also, Dyson customer support is pretty good. Contact them for a service location or additional troubleshooting suggestions.
Re: Any Vacuum experts? :) [Re: maverickfhs] #5216712 09/19/19 05:54 AM
spavel6 Offline
If you have a torx bit, you can take apart the cyclone section to clean it out. I used to service a bunch of these, and they get nasty in the actual cyclone section (you can't see it from the outside.
My guess is the cyclones are clogged if you aren't getting much suction at the wand.
A bunch of videos on youtube as to how to take apart the cyclone section.
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT
2001 VW GTI VR6 250k T6 5W40
2001 VW Passat Wagon V6 4motion 110k PP 5W30
Re: Any Vacuum experts? :) [Re: maverickfhs] #5216721 09/19/19 06:14 AM
SteveSRT8 Offline
If it is a ball you must check the valve at the base of the handle that switches you from floor suction to wand. I have had debris both block the passage and also simply prevent the seal from diverting the suction to the wand.
As stated above, thorough cleaning is the key. Be cautious about jabbing into the passages as Dyson has very soft seals that can be easily damaged...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Any Vacuum experts? :) [Re: SteveSRT8] #5216748 09/19/19 06:50 AM
M
M
I think that's exactly what it was, I have disassembled the bottom part and cleaned a lot of debris. Not sure if I'll be able to put it back together again?
Re: Any Vacuum experts? :) [Re: maverickfhs] #5216877 09/19/19 09:09 AM
A
ARCOgraphite Offline
A
Oh, i thought you would have a Sebo or a Miele.
Sound like there is a clog in the 'ball" area.
There must be some youtube videos on how to fix this plastic fantastic.
I'm into vacuums as an engineer, amazing how terrible 99% of them are in design AND construction.
I'm still using a wand and rubber brush head from a late 60's Eureka canister on my Italian ERMER since the new ones are junk.
Good luck and don't loose any parts!
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Any Vacuum experts? :) [Re: maverickfhs] #5217138 09/19/19 01:52 PM
J
JLawrence08648 Offline
J
I've had 3 Dysons, and many others. Shark is the best, no clog, sucking is good, easy to take apart to clean.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Any Vacuum experts? :) [Re: JLawrence08648] #5217185 09/19/19 02:51 PM
Inked Offline
Agree 100% ^^^
2017 Acura MDX
2007 H/D FLSTC
Early is on time; on time is late; late is unforgivable.
Re: Any Vacuum experts? :) [Re: maverickfhs] #5217253 09/19/19 04:52 PM
B
bobdoo Offline
B
The cyclone sections clog up. There's directions on the web on how to clean them out.
Re: Any Vacuum experts? :) [Re: maverickfhs] #5218537 09/21/19 06:38 AM
M
M
Was able to put it all back together and it was a clogging in the wand area, causing it to cut out.
