I need to replace the A/C compressor on my CRV. Its having clutch and/or thermal switch issues. Compressor its self cools great and doesn't make any noise when its running. Question is if the system hasn't leaked out, and the compressor itself is fine is there any reason to replace the condenser and the receiver/drier (getting to the drier involves removing the condenser)? I ordered a Denso compressor but didn't order anything else because in my mind at least there is no reason to replace either if the system is clean and only open momentarily.
