Originally Posted by supton
I have the 4x8 and like it quite a bit, actually. It's flimsy but it works great with the typical small FWD car--one will never load it, given its flimsiness, which means it'll never overload the typical FWD sedan. I've thought about getting the smaller size for pulling behind the lawn tractor and moving yard debris, but haven't gone that far yet.
Only downside is metric wheel bearings, but they're actually cheap if you buy them through HF.
How about a dust cover? I lost one of mine. Supposed to be 52mm. A 52mm one doesn't fit.
The bearings I have had good luck with ones from Amazon. Although I have found if you load the 1170 pound trailer with >2500 of cinder blocks and dirt, you will destroy the wheel bearings.
