The ole’ robin egg passed
by 53' Stude - 05/30/20 03:33 PM
Left OR Right?
by MolaKule - 05/30/20 01:46 PM
Space X launch
by MrQuackers - 05/30/20 01:33 PM
Rotella Truck 5W-30 Disco'ed at Home Depot
by josephp732 - 05/30/20 01:17 PM
320K mileage - recommendations?
by joshuawesl - 05/30/20 12:36 PM
ISO Sprint sim
by pkunk - 05/30/20 11:44 AM
2001 Mazda Miata, timing belt
by frankbee3 - 05/30/20 11:15 AM
3M tape removal
by loneryder - 05/30/20 10:31 AM
Which string trimmer
by DeafBrad - 05/30/20 10:26 AM
Conventional Oil Benefits
by Bogdon - 05/30/20 07:38 AM
I'm finally retired!
by grampi - 05/30/20 07:20 AM
2020 Equinox 1.5t
by IMPALA08 - 05/30/20 07:05 AM
Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Dermented, Twostick, davecrobinson, YardWork, Moonray
71577 Registered Users
82 registered members (53' Stude, aquariuscsm, 14Accent, 77GrandPrix, 928, Ag76, 10 invisible), 2,508 guests, and 23 spiders.
Topics306,048
Posts5,285,632
Members71,577
Page 1 of 5 1 2 5
Uniform molecule size and viscosity modifiers #5215678 09/17/19 10:46 PM
R
Rav4H2019 Offline OP
R
When viscosity modifiers are added to a synthetic base oil, say in m1 0w20 ep or 0w40, then at operating temperature are all the molecules of same size ? Uniform molecule size is touted in selling synthetic oils. Are the molecules from the viscosity modifier larger than those of base oils?
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5215734 09/18/19 03:17 AM
F
FordCapriDriver Offline
F
The whole molecule size thing ( from what i've been able to gather ) is more of a marketing gimmick than anything.
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5215813 09/18/19 07:14 AM
E
Eddie Online Sleepy
Online Sleepy
E
We need the data from a Chemist who works for an oil company to answer that. Ed
2014 CX5 Touring 2.5L :-)
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5215815 09/18/19 07:17 AM
B
Boomer Offline
B
Not all the same size but probably the distribution curve of molecular weight/size is much narrower for a PAO or a GTL oil than one that is refined from dino drippings.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5215888 09/18/19 08:35 AM
M
Mad_Hatter Offline
M
What the heck, I'll take a stab at this. I don't think they are all exactly uniform in size, otherwise you wouldn't have permanent shear loss. So some of the uncoiled VM polymers get chopped up, reducing the VM's ability to resist the flow of the base oils molecules.
Now there are really high quality VM's that better resist this shearing. You see these used in extended drain lubes for example.
( I've read that higher molecular weight VM polymers do a great job of thickening the oil but are more prone to shear (larger size??) and the treat rates are lower when using these high molecular weight VM's. Conversely, low molecular weight polymers are better at resisting shear but not so much at thickening hence the treat rate (quantity needed) is higher)
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5216010 09/18/19 10:31 AM
N
ndfergy Offline
N
It’s a bunch of marketing baloney.
Think about it logically. Molecular size is measured In Angstroms.
1 angstrom = 1/10,000 Microns
1/1000 of an inch or mil is used in engine measurement = 25 Microns
An oil molecule = ~30 Angstroms
The argument that synthetic oils molecular size being more uniform than conventional is completely irrelevant in a fully formulated motor oil when only ~80% is base. VM’s are significantly larger - not to mention some of the other hodgepodge of ingredients that may be too.
2015 Toyota Yaris 5spd Manual
Summer: Mobil Super 1000 10w30
Winter: Mobil Super 1000 5w30
OEM Filter
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5216014 09/18/19 10:41 AM
R
R
So when synthetic oil with VM''s is being squeezed in between two metal plates, VM''s are providing the padding at operating temperature they are larger ?
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5216021 09/18/19 10:53 AM
P
Pelican Offline
P
This goes back to the 70's when I started using synthetic oil; At that time it was stated that dyno oil has 3 types of molecules small-medium & large.
The small & large molecules get burnt off and end up as deposit on your valves and piston head while the medium size ones lubricate.
I'm pretty sure that may not be possible to make all the molecules, no matter the category, uniform in size so there must be an amount of give & take.
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5216055 09/18/19 11:23 AM
R
R
So when synthetic oil with VM''s is being squeezed in between two metal plates, VM''s are providing the padding at operating temperature SINCE they are larger ?
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5216067 09/18/19 11:31 AM
N
ndfergy Offline
N
Now we’re getting into pocket protector territory (not meant in the pejorative) of temporary polymer shear. What I understand is this phenomenon always occurs when the oil is squeezed enough between two surfaces for the VM polymers to align themselves like nesting spoons. To what degree of VM type and the base oil viscosity comes into play is the 64 thousand dollar question best answered by more learned members.
For further edification research traction coefficient and pressure viscosity constant on this topic. Very interesting reading.
OEM Filter
Re: Uniform molecule size and viscosity modifiers [Re: Pelican] #5216069 09/18/19 11:33 AM
R
R
So the smaller ones burn off as they are more prone to burn off. ? And the larger ones are carrying the load so to speak and hence burn off ?
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5216073 09/18/19 11:36 AM
sloinker Offline
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Uniform molecule size and viscosity modifiers [Re: ndfergy] #5216086 09/18/19 11:48 AM
M
Mad_Hatter Offline
M
Really?
Setting fully synthetics PAO aside, Grp3 synthetics are hydrocracked.. the breaking of long change hydrocarbons into smaller uniform molecules. The resulting (designer) base oil has superior (to mineral) oxidative and thermal stability, higher VI and the highly processed (cracked) oil has a lower "traction coefficient" (lubricant friction) then grp2 mineral oils because of molecular uniformity.
Some Grp3 base stocks like Shell's GTL rival PAO in performance and some highly processed Grp2+ oils have viscosity indexes approaching Grp3. Chevron for example has a grp2+ with a VI of 118(119??) with a volatility of a grp3.
Synthetics v. Mineral
Re: Uniform molecule size and viscosity modifiers [Re: FordCapriDriver] #5216096 09/18/19 12:00 PM
RDY4WAR Online Content
Online Content
Ditto.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Uniform molecule size and viscosity modifiers [Re: Rav4H2019] #5216101 09/18/19 12:06 PM
SubieRubyRoo Offline
I vote Ravenol for the best marketing program. /tongue in cheek
Even if their PDFs like the one linked are pure marketing hooey, it means something to me when a company will spend the time to tell you about its products in greater depth than competitors do. I've used the Ravenol DXG, and it seemed like a good oil other than I got d1G1 oil in a jug labeled d1G2; but since my vehicles don't require either cert, I use it anyway.
I'll be putting it in my Impreza before it snows, replacing some Amsoil SS 10W30.
De omnibus dubitandum.
Page 1 of 5 1 2 5
