Forums Migration
Please read this thread
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
109 registered members (2003f7, 92saturnsl2, 55hambone, 97trophy, alchargo, 4WD, 9 invisible), 2,045 guests, and 26 spiders.
Topics307,576
Posts5,313,394
Members71,876
Typical generic TPMS install costs #5215459 09/17/19 05:23 PM
P
Patrick0525 Offline OP
P
I called the Lexus dealer for new tmps install. He said $212 for the 1st tire and then $173 for the others which included sensor, relearn ids to ECU upload and breaking the bead. No balancing included. That is a grand of $731.
I did some research and I could buy an eBay Autel TS508 TPMS tool & senior kit which includes 8 TPMS for $320, I would clone the Lexus ids into the new Autels and do a valve stem replacement at the local independent garage for $40. That grand total is $360 plus I would have a tmps tool to do good deeds with and four 433mhz Autel sensors valued at $120,
If I sell the sensors at $100, my net costs would be $260.
For $220 the breakdown includes 4 sensors and a TS508. This would mean I paid $100 for the tool. Not bad.
My wife says I should not do this since the local garage mechanic needs to feed his family and buy shoes for the kids.
She is probably right, but I think I will keep on dreaming,
2014 Toyota Venza 2GR-FE 96K mi
2009 Lexus ES350 2GR-FE 49K mi
Fram Ultra filter XG9972
TGMO or Idemitsu Zepro 0w20 (winter)
PP 0w20 (spring/summer/fall)
Re: Typical generic TPMS install costs [Re: Patrick0525] #5215472 09/17/19 05:51 PM
L
Lolvoguy Offline
L
I wouldn't recommend the aftermarket offerings.
I would however recommend building a TPMS canister/pipe bomb.
Very popular mod over on the Lexus boards. If my sensors were failing, that's the first thing I'd think of!
IIRC, once you convert to the canister setup, you can run regular valve stems in your current wheels (no more need to remove tires to replace the sensors etc).
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/328044-diy-tpms-canister-pipe-bomb.html
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Typical generic TPMS install costs [Re: Patrick0525] #5215478 09/17/19 06:02 PM
bdcardinal Offline
Devils advocate, if something goes wrong in the shop, they fix it and have a warranty. If it goes wrong on your own, you are your own warranty.
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Typical generic TPMS install costs [Re: Patrick0525] #5215484 09/17/19 06:19 PM
R
Reddy45 Offline
R
But we're talking about a 2009 Lexus right? What warranty exists on a 10 year old vehicle, besides the one that would come with a $731 TMPS replacement job?
Re: Typical generic TPMS install costs [Re: Patrick0525] #5215486 09/17/19 06:21 PM
J
JustinH Offline
J
Discount tire did them for my sonata for $45 each.
They had to do the job twice because the first manufacturer was not compatible with my system.
Let them do it.
Lexus is probably Denso, probably cheap.
'16 Ford Escape
'11 Scion XB
Re: Typical generic TPMS install costs [Re: Reddy45] #5215487 09/17/19 06:23 PM
bdcardinal Offline
Warranty as in something happens with the current sensors.
Re: Typical generic TPMS install costs [Re: Reddy45] #5215488 09/17/19 06:25 PM
P
P
I assume the Lexus parts warranty is similar to the Toyota parts warranty of one year,
Re: Typical generic TPMS install costs [Re: JustinH] #5215495 09/17/19 06:33 PM
P
P
Let them do it.
That’s a bargain. Do u know what manufacturer they put in?
Re: Typical generic TPMS install costs [Re: Patrick0525] #5215525 09/17/19 07:17 PM
W
Wolf359 Offline
W
Lots of tire shops have the tools to do all sorts of cars. Just call and ask. And they probably just charge the normal $5-$10 to rebuild them. I think when I was at Costco and had a bent rim, they only charged me $15 to swap the sensor. I suppose if you just bought the right sensors, a tire shop should be able to swap them and program them for you assuming they have the right tools.
They don't call them stealerships for nothing.
Re: Typical generic TPMS install costs [Re: Patrick0525] #5215542 09/17/19 07:46 PM
E
Elkins45 Offline
E
You could always do what my wife does: just let the light stay on all the time smile
Re: Typical generic TPMS install costs [Re: Patrick0525] #5215564 09/17/19 08:19 PM
A
atikovi Offline
A
There are a set of 4 sensors on Ebay for around $50.
Re: Typical generic TPMS install costs [Re: atikovi] #5215585 09/17/19 08:54 PM
E
eljefino Offline
E
And the hacked techstream software plus cable for another $20.
"Pacific" brand = Denso = OE.
Re: Typical generic TPMS install costs [Re: Patrick0525] #5215599 09/17/19 09:05 PM
H
hallstevenson Online Content
Online Content
H
I bought VDO sensors off of Amazon for $52 for a 2-pack (they're currently $67) and Discount Tire installed them. I want to say it was about $20/tire, which also included programming the sensors and (re-)balancing the tires. Walmart's tire center will do them as well. The one near me was about $10/tire plus $19 for programming or $60 total. I ended up at Discount Tire - where I always buy tires from - because WM wasn't "convenient" (said I'd have to leave my car and it would be 4-5 hours before they could get to it). I was in and out of DT in under an hour.
Here's the VDO part for a Lexus ES350: https://smile.amazon.com/VDO-SE1000...;qid=1568772008&s=gateway&sr=8-1
Re: Typical generic TPMS install costs [Re: hallstevenson] #5218460 09/21/19 02:34 AM
M
Mackelroy Offline
M
Why do they have to rebalance the tires, you only half to break down one sidewall to replace, tire doesn't move on the rim.
Re: Typical generic TPMS install costs [Re: Mackelroy] #5218464 09/21/19 03:13 AM
P
P
Some shops take the entire tire off the rim to install the TPMS.
