Havoline ProDS Syn 10W-30 $19.73 6-pack
by Jackson_Slugger - 10/23/19 03:02 PM
Wix Oil Filter Rating Question
by 02vito - 10/23/19 02:30 PM
Help me decide between Fram and Mobil 1
by ZiTS - 10/23/19 02:13 PM
2003 BMW E46 M3 Rotella 15w40
by Manners226 - 10/23/19 02:10 PM
Firearm solvent/oils
by HyundaiAbuser - 10/23/19 01:56 PM
Coloured wax
by Propflux01 - 10/23/19 01:36 PM
Elk Jerky
by 28oz - 10/23/19 01:15 PM
If idle is to be avoided?
by Rglossip - 10/23/19 01:01 PM
Beck Arnley Brake Pads FMSI Materials?
by jrvn - 10/23/19 12:39 PM
Aging - What the ....
by coopns - 10/23/19 12:13 PM
Chevron Supreme 5W20 Bay Area Trade/Sell
by e55amgbenz007 - 10/23/19 10:07 AM
Auto Extra 51348 Vs Napa Gold 1348
by BeerCan - 10/23/19 10:05 AM
Latest Scam Method?
by 2015_PSD - 10/23/19 09:47 AM
Medical bills from 3 year back
by stockrex - 10/23/19 09:31 AM
2019 Nissan Pathfinder CVT drain/fill.
by JTK - 10/23/19 09:19 AM
Do I need Intel RST?
by Quattro Pete - 10/23/19 08:50 AM
Anabond 230 for bonding brake linings
by sdowney717 - 10/23/19 07:29 AM
2010 Mazda 3 FL400s options
by Sixxer - 10/23/19 06:50 AM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
101 registered members (53' Stude, 2002 Maxima SE, 4WD, 2010Civic, 72te27, 02vito, 3 invisible), 2,178 guests, and 32 spiders.
Topics296,391
Posts5,096,795
Members69,652
Most Online3,532
Jul 30th, 2019
Offset print oil #5215338 09/17/19 03:06 PM
M
Matt_Pill Offline OP
M
Not sure this forum has the techs who work but a long shot.We engage in www.deluq.com mostly to India, link is basic but directional. Most of these machines mainly Komori or Hedelberg we always use regular conventional lubrication oil tear down or set up but hear a lot about H1 high-performance lubricants. Any one here who does machinery install or have experience with printing or packing machinery oil usage especially given some of them are used in food industry?
Re: Offset print oil [Re: Matt_Pill] #5215405 09/17/19 04:14 PM
MolaKule Offline
Global Moderator
Global Moderator
Why would you need a Food Grade lubricant unless your print products come into direct contact with food products?
"You ... sadist," said Mr Cummings, "you try to make people think." Ezra Pound (1885-1972)
Re: Offset print oil [Re: Matt_Pill] #5215474 09/17/19 05:53 PM
L
Lignums Offline
L
Why not use what is recommended in the operation manual?
1998 Chevy w/t 1500 4.3. 247,000
2004 Buick Lesabre 3.8 200,000
2006 Gmc envoy xl 5.3. 183.000
2018 Honda Crv 2.4. 11,000
2007 Chevy Aveo 62,500
Re: Offset print oil [Re: Matt_Pill] #5215501 09/17/19 06:41 PM
P
philipp10 Offline
P
if there was ever a time to say "just use any 10 to 30 weight oil it would be now. These are not tough applications for lubrication.
Re: Offset print oil [Re: Matt_Pill] #5215598 09/17/19 09:01 PM
B
bernardch Offline
B
I managed the maintenance department for a large web and sheetfed printer for 12 years. On the web side it was Heidelber/Harris M1000 and Komori System 38 presses. Sheetfed presses were Heidelberg Speedmasters and MAN Roland R700 series. We were a Mobil house. In the oil room we had MobilGear SHC 627, 629, and 630 oil, alongvwith a Mobil Vactra #2 and various DTE oils for balers and flat cutters.
I know the M1000s were SHC630. I believe the sheetfeds were 627 and 629 depending on manufacturer. Anytime we'd get new equipment I'd give the OEM oil name and specs to my Mobil rep and they would cross reference to a Mobil product.
Although our SHC oils had similar numbers, they were not interchangeable. One Sunday night the press crew was doing a full press oil change on our six unit M1000. The pressrooom forgot to order SHC630, so the press helper saw the 629 and thought, 629, 630 they got to be almost the same and filled all six print units, 38 gallons each unit 629. We had to drain, flush and refill all units with 630. Both oils ran about $15/gallon! That was a $7000 mistake. The oil room was locked after that incident.
As far as food grade greases, contact any of your local printing suppliers (Prisco, etc.). They have multiple food grade options for delivery chains and such.
CB
Re: Offset print oil [Re: bernardch] #5215772 09/18/19 06:20 AM
M
M
Thank you, your response is the most practical and experienced. We use Mobil all day on all machines as well but apparently there are new age lubricants being pushed from Japan and Germany. Wow, that that helper issue is so unfortunate, probably lack of training.
Re: Offset print oil [Re: MolaKule] #5215775 09/18/19 06:24 AM
M
M
Well it does, depending on the printing use. Some of the packaging in less strict countries just goes directly wrapping the food products, eitherway thats what the customer wants!
Re: Offset print oil [Re: Matt_Pill] #5216008 09/18/19 10:29 AM
MolaKule Offline
Global Moderator
Global Moderator
Here is some info on the classes of food grade lubricants (FGL):
Food Grade Lubricants
I would find out from your customers exactly which Category of FGL you must meet so you don't purchase overly expensive FGL's you don't need.
Companies such as Lubrication Engineers, Schaeffer Oil, Amsoil, and others produce FGL's.
Re: Offset print oil [Re: Matt_Pill] #5217202 09/19/19 03:16 PM
L
Lignums Offline
L
The new machines require ISO-VG68. Mobilgear 600XP68. Same as it has always been. The oil in the press is not an issue, the grease, and ink and other chemicals are, those MUST be food grade.
Re: Offset print oil [Re: Matt_Pill] #5220015 09/22/19 08:18 PM
R
RDMgr Offline
R
Use the NSF White Book to help you select oils, greases, inks, etc. for use on food machinery. www.nsf.org/services/by-industry/food-safety-quality/nonfood-compounds is the website where you can find the White Book that lists all of the certified materials of this type. You can also find the certification letters for the various materials of interest on the website.
Re: Offset print oil [Re: Matt_Pill] #5221355 09/24/19 01:33 PM
MolaKule Offline
Global Moderator
Global Moderator
As to inks, i think most ink oils these days are either soy or soy-ester based ink oils.
