Originally Posted by hallstevenson
Originally Posted by Wolf359
I'm not sure if most people on this thread realize it, but gas in one area pretty much all comes from the same source. So the only difference between gas stations is the additive package. So brand loyalty doesn't really matter, that's just being hooked by the brand.
Remember, this is the same crowd that critiques the composition or additives used in engine oil or folks that believe, with no proof at all, that anything other than "Top Tier" fuel will cause your engine to fail "soon". I'll use gas from Kroger because of the points we have that reduce the per-gallon price. I'll use Murphys (a la Walmart gas) because it's next door to a Speedway and Speedway is notorious for raising prices 30 cents, 50 cents, even 60 cents in a single jump while this Murphys holds their lower price for a day or two. I wanted to use Shell more often after I installed their phone app thinking I'd save a little bit every time but then it looks like I need a 2nd app, Fuel Rewards, but that still didn't work. Looks like I have to use a Shell credit card or something. Then again, I don't care at this point as it's not worth that hassle.
I roll my eyes over this Top Tier marketing gimmick. I checked multiple stations around this area that are on "the list" but otherwise have no physical indications that they actually follow the TT rules (i.e. sticker on pump).
What I've noticed is that whenever there's some cheap gas program, it's cheap initially, then it's no longer cheap. Used to go to Stop and Shop, they offered 10 cents off a gallon so it was somewhat decent for a while as after the 10 cents, it was a few cents cheaper than the cheapest station. But then their prices started creeping up and you had to spend at least $100 to get the 10 cents off per gallon so it wasn't worth it to make sure you shopped there all the time. There are BJs and Costco gas stations near me where they usually have pretty good prices plus a few indys that I think might be fronts for money laundering that always seems to have low prices but are cash only. There's also Cumberland Farms, same deal, the member price used to be cheap as it was an extra 10 cents off the pump price, but now they're not always competitive. They give you a free drink of some type every few weeks so sometimes I just stop by for the free drink and not even get any gas.
I also use the cheap gas. According to the crowd, I better start looking for a new vehicle as mine is a time bomb ready to fail at anytime!
I don't think people think that. I think they think they're babying their car and it will last long. But it's just a hunk of metal put together in a certain way. No real evidence that says your car will run longer if you use top tier gas. It's all good marketing. Yeah, it might be good if you have a problem, but if you don't, it's a waste of money. When the car breaks, it's never because of the gas.
