Forums Migration
Please read this thread
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
104 registered members (2003f7, Anthony, AlienBug, Alaskanmont, 2004tdigls, 2015_PSD, 9 invisible), 2,092 guests, and 26 spiders.
Topics307,575
Posts5,313,381
Members71,876
Any BMW LL04 recommendations? #5215293 09/17/19 02:18 PM
M
M3m3x5 Offline OP
M
I’ve been using the Mobil 1 ESP Formula 5w30 for my diesel which requires LL04 oil but I’ve finally run out of my stash. It seems there isn’t much to pick from except from the dealer who sells the BMW branded oil. Is there any better? It seems I can’t find any LL04 oil the local car parts shops so it looks like I’ll have to order online. How do Motul, Castrol, Pentosin, etc rate amongst themselves? Any help would be appreciated
Re: Any BMW LL04 recommendations? [Re: M3m3x5] #5215297 09/17/19 02:23 PM
B
Bjornviken Offline
B
Pennzoil 5w-30 euro have the LL04.
Last edited by Kestas; 09/17/19 02:49 PM. Reason: no need to completely quote the first post in the second post
Re: Any BMW LL04 recommendations? [Re: M3m3x5] #5215331 09/17/19 02:55 PM
J
Jimmy_Russells Offline
J
Total Ineo LongLife can be had on Amazon in the three pack for a decent price. Also Ravenol VMP in the 20L box in on a good sale right now at BlauParts.
Re: Any BMW LL04 recommendations? [Re: M3m3x5] #5215335 09/17/19 03:01 PM
slacktide_bitog Online Content
Online Content
PP Euro L is LL-04 and available at Walmart in the 5qt jug smile
Re: Any BMW LL04 recommendations? [Re: slacktide_bitog] #5215339 09/17/19 03:07 PM
J
J
This is good choice too. For some reason I was thinking this is hard to get in USA but maybe that's only true for the LX.
Re: Any BMW LL04 recommendations? [Re: slacktide_bitog] #5215406 09/17/19 04:14 PM
B
Bjornviken Offline
B
What is the price of this oil?
Re: Any BMW LL04 recommendations? [Re: Bjornviken] #5215431 09/17/19 04:43 PM
JohnnyJohnson Offline
https://www.walmart.com/ip/Pennzoil-Platinum-Euro-L-5W-30-Full-Synthetic-Motor-Oil-5-qt/495194903
2004 Corolla 140638
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Any BMW LL04 recommendations? [Re: Bjornviken] #5215494 09/17/19 06:31 PM
Online Content
About $25 for a 5qt jug. A single quart is about $7
Re: Any BMW LL04 recommendations? [Re: M3m3x5] #5215507 09/17/19 06:51 PM
M
M3m3x5 Offline OP
M
That’s interesting on the Pennzoil. And it’s advertised as full synthetic. That’s probably the stuff the dealer sells.
What about pentosin super performance III? How does that rank? I’m not really concerned about price as I change oil maybe once or twice a year
Re: Any BMW LL04 recommendations? [Re: M3m3x5] #5215530 09/17/19 07:27 PM
J
J
BMW switched to Shell a couple years ago so it’s likely the BMW oil is the same as the Pennzoil.
I’ve never used Pentosin oil but have used other fluids. If it carries the right approvals, it’s good to go.
Re: Any BMW LL04 recommendations? [Re: M3m3x5] #5215579 09/17/19 08:42 PM
M
M3m3x5 Offline OP
M
I have no understanding of the way oils are made, so how is Pennzoil able to sell that oil so cheap? And the bmw branded Pennzoil is about $7 (obviously a major markup but still very cheap). That’s probably less than they charge for windshield washer fluid. Has me confused
Re: Any BMW LL04 recommendations? [Re: M3m3x5] #5215586 09/17/19 08:55 PM
J
J
I don’t know what it costs them, but every major manufacturer typically has 5 quart synthetic jugs for around $18-23 each, depending on the product line. You can pay more for boutique oil if you want, but it doesn’t guarantee a better product.
Also you can actually get an online rebate for that oil too, making it dirt cheap.
https://www.pennzoil.com/en_us/prom...eS9TcHJpbmdNSVIxOS9zdG9yZWxvY2F0b3IuY2Zt
Re: Any BMW LL04 recommendations? [Re: M3m3x5] #5215696 09/17/19 11:35 PM
B
Bjornviken Offline
B
Same oil cost 40€ for 4 L over here. But its name is shell helix ultra ect 5w-30.
Re: Any BMW LL04 recommendations? [Re: Jimmy_Russells] #5215700 09/17/19 11:42 PM
B
Bjornviken Offline
B
PP Euro L Typical properties is pretty darn good
Re: Any BMW LL04 recommendations? [Re: M3m3x5] #5215713 09/18/19 01:12 AM
edyvw Offline
PP Euro L is not the same as BMW TPT 5W30 LL04. Different pour point, and BMW TPT has extremely low NOACk (6.8%).
Pentosin Super Performance III is true synthetic oil, and you really cannot go wrong with it. It is step up from PP Euro L. Now, is it worth the price difference, that is questionable.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
