Forums Migration
Please read this thread
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
108 registered members (Alaskanmont, 2004tdigls, 2015_PSD, Aichiguy, 2K2AcuraTL, Alfred_B, 10 invisible), 2,116 guests, and 29 spiders.
Topics307,575
Posts5,313,366
Members71,876
Recommend Costco tires #5215277 09/17/19 01:58 PM
H
henni Offline OP
H
Have to replace 2 but am leaning toward purchasing whole set from Costco this week as they are running one of their specials.
Which Michelin tire do you like and wasn't there one Michelin model sold by Costco known to have a very small thread depth aka. pre-shaven tire which would logically wear off faster than normal depth ?
In the deep south I value most quiet highway handling and safety during heavy rainfalls.
As to date codes on the tires, am assuming anything with a WWYY in the pattern of xx19 would be Ok ?
Does Costco hand torque aluminum wheels so I can safely trust they will not exceed 80 ft-lbs (..or bring my own digital torque wrench and verify) ?
Anything else I am missing but should know ?
Re: Recommend Costco tires [Re: henni] #5215284 09/17/19 02:11 PM
Donald Offline
You should read up on the tires on TireRack and then buy from Costco if cheaper.
Most places will partially tighten with impact and finish with torque wrench. Or use torque bars. But they will torque to the spec their computer lists.
2015 Ford F-250 w/Powerstroke
Re: Recommend Costco tires [Re: henni] #5215295 09/17/19 02:19 PM
slacktide_bitog Offline
What tire size do you need? smile
Re: Recommend Costco tires [Re: henni] #5215304 09/17/19 02:33 PM
W
wdn Offline
W
Costco does not shave their tires. They do sell some club only tires that are identical and I mean identical, to another Michelin tire. For example Michelin X LT tire from Sam's Club is the Michelin Defender LTX. The X TOUR A/S T+H from Costco is the same as the Defender T+H.
They will also sell both the familiar model Michelin tire in the same club as the "club brand" tire the only difference is the price. Either way the tread depth is the same and the tread pattern the same, they are identical tires except the model name printed on the sidewall.
The Michelin Latitude tires have less tread depth maybe that is what you are referring to but it is no different at Costco
Re: Recommend Costco tires [Re: henni] #5215322 09/17/19 02:44 PM
J
JayhawkRoy Online Content
Online Content
J
You need to check for tire availability.
Right now, my nearest Costco has no Michelin tires that fit your Ridgeline in stock. The Michelin deal is good until 1 Oct, and it takes 5-10 days for a special order to show up. When I used Costco for tires, they hand torqued all lug nuts, and they recommended that you return for a re-torque in about 50 miles. My serivce was generally good but the waits for free balance and rotate could be long.
Re: Recommend Costco tires [Re: henni] #5215326 09/17/19 02:50 PM
N
nthach Offline
N
For the Ridgeline, stick with the Defender LTX although Honda switched over to Bridgestone Dueler HL400s on the 2nd gen trucks.
You're talking about the Michelin Premier series that has less tread depth(8.5/32") but makes up for it with a sunflower oil enriched silica compound and much more siping, with some of those being keyhole sipes that get bigger as the tire wears. It's a good tire but not my choice if you plan on though light snow. Michelin designed that tire for the American market and targeted the Accord/Camry for the Premier A/S, while the Lexus RX was the development target for the Premier LTX.
Re: Recommend Costco tires [Re: henni] #5215328 09/17/19 02:53 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
The last time I wanted Michelin tires for my car I shopped around and found Costco was the cheapest. This included Tire Rack and Discount Tire.
Had I decided to do my own mounting and balancing with Tire Rack, I would have only saved $20 from the Costco out-the-door price. Not worth it.
Re: Recommend Costco tires [Re: Kestas] #5215346 09/17/19 03:14 PM
W
Wolf359 Offline
W
Not only that, but Costco does lifetime balance and rotation plus 5 year road hazard. Usually when I get a vibration, I get them balanced. If you have to pay for it, it's probably going to be more than $20 to balance 4 tires. It's worth it just for the road hazard. And as luck would have it, I had a couple of flats previous with Michelin's that came with the car and then Pirelli, but since I got the latest set of Michelins two years ago, no flats so haven't been able to take advantage of their road hazard. Which is good. When they run their $70 off and 1 cent installation, no one can touch them on the price. Now they just do $40 off instead of 1 cent installation.
Re: Recommend Costco tires [Re: henni] #5215374 09/17/19 03:48 PM
H
henni Offline OP
H
Thank you for all replies.
If I am NOT a member after next year, do they still honor the .
Quote
...Costco does lifetime balance and rotation plus 5 year road hazard ..
.... ie. does the purchase date override membership expiration date ?
Re: Recommend Costco tires [Re: henni] #5215395 09/17/19 04:06 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Costco sells high end tires (Michelin) and budget tires (BF Goodrich) with prices that are hard to beat. If you want something in particular, you'll have to go elsewhere.
For example, my summer car used to get Michelin summer sport tires. But now I have to compromise and get the Michelin touring tires.
Re: Recommend Costco tires [Re: Kestas] #5215398 09/17/19 04:09 PM
JohnnyJohnson Online Content
Online Content
Costco doesn't do alignments any place I'm aware of just some food for thought and planning out your new tires.
2004 Corolla 140638
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Recommend Costco tires [Re: JohnnyJohnson] #5215524 09/17/19 07:12 PM
W
Wolf359 Offline
W
I usually just get a 3 year alignment warranty at Goodyear. Firestone, NTB and a few other places also offer some type of alignment warranty.
Re: Recommend Costco tires [Re: henni] #5215609 09/17/19 09:23 PM
Spartanfool Offline
Quote
When I bought a car battery, I had to renew my expired membership before they would honor the warranty.
Re: Recommend Costco tires [Re: Spartanfool] #5215651 09/17/19 10:07 PM
W
Wolf359 Offline
W
Yeah, they always require a membership card to do any work. I suppose if you're really cheap, you can always sign up and then cancel to get your money back on the last day. Then repeat next time you need to bring it back in. They offer a full refund at any time on your membership.
Re: Recommend Costco tires [Re: Spartanfool] #5216661 09/19/19 02:09 AM
P
pitzel Offline
P
Weird. I returned a Costco-purchased battery with no membership and it was no problem. They refunded to a gift card.
