Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
Zip ties and bias plies on YouTube
by 53' Stude - 01/25/20 09:00 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
Low VI gear oils
by dparm - 01/25/20 05:28 PM
Removed valve cover, need to move car change oil?
by mazdamonky - 01/25/20 05:23 PM
Lucas UCL and turbos?
by K20FA5 - 01/25/20 05:01 PM
Another reminder why I always change my own oil
by DreamerGT - 01/25/20 04:52 PM
Oil for my 65 mustang.
by old1 - 01/25/20 04:12 PM
Carburetor Tuning with Wide Band O2 Sensor
by Oldswagon - 01/25/20 03:16 PM
Software fix for blown headgasket?
by CaptainHazelwood - 01/25/20 02:01 PM
EB Oil Drain Plug
by BlueOvalFitter - 01/25/20 01:59 PM
Grease for Blend Door Actuator
by TheLawnRanger - 01/25/20 01:05 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
103 registered members (AnthemBassMan, 2009Caraman, 53' Stude, 4WD, atikovi, antone, 10 invisible), 2,602 guests, and 17 spiders.
Topics300,561
Posts5,178,352
Members70,527
Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX #5215195 09/17/19 10:51 AM
05UFCaptain Offline OP
Long time lurker, first time poster here. So, please bear with me if my searching has failed to find a thread that has already answered my question(s).
According to Bendpak, "Approved fluids are any general purpose ISO-32, ISO-46, or ISO-68 Hydraulic Fluid, approved Automatic Transmission Fluids such as Dexron III, Dexron VI, Mercon V, Mercon LV, or any synthetic multi-vehicle Automatic Transmission Fluid."
Although it never really gets cold here in southeast Florida, I am planning to fill the system with something like either Miles Ultihyd Bio ISO 32, Super Lube Synthetic ISO 32-46, or Renewable Lubricants Bio-Food Grade ISO 32 because, based on my admittedly limited knowledge, my first choice is to use a clear, synthetic, anti-wear, iso 32 hydraulic fluid.
Besides the cost, is there any reason that I should not use one of those hydraulic fluids? If so, what's a better alternative/why? From system efficiency and from anti-wear perspectives, would a Dex, Merc, or universal synthetic ATF or another hydraulic fluid be superior? If so, feel free to learn me up! Thanks in advance.
Re: Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX [Re: 05UFCaptain] #5215203 09/17/19 10:57 AM
Astro14 Offline
I had some leftover AMSOIL signature series multi vehicle when I filled up my quick jack.
Works fine.
I don’t think this thing really cares. Use ATF because it’s cheap, or you have it on hand, or if you’ve got tractor fluid on hand, use that. Change it out every couple years.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX [Re: 05UFCaptain] #5215206 09/17/19 11:05 AM
R
ragtoplvr Offline
R
If you are in commercial service bending pipe continuously then a good syn fluid would be useful. For a tail pipe shop where it runs 10 minutes every hour almost anything would work.
Rod
Re: Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX [Re: ragtoplvr] #5215215 09/17/19 11:20 AM
Astro14 Offline
This is for a QuickJack.
Bendpack is the manufacturer.
Here’s the unit in question:
https://www.quickjack.com/car-lift-systems/bl-7000slx-portable-car-lift.html
Photo of one taken a minute ago.
[Linked Image]
32 Packard 15W40
05 MB S600 0W40 M1
Re: Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX [Re: 05UFCaptain] #5215227 09/17/19 11:40 AM
W
WhizkidTN Offline
W
I really enjoy mine! Costco has them for $999 for the BL-5000SX (some of been spotted for $899). Just go to their website to see the method of measuring your car(s) jack points to ensure you either get the right model or also purchase the extender (makes it the same as the BL-7000SX which i had to do).
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (87K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (97K)
>EDGE 0W-20, Fram XG6607/XG7317
Re: Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX [Re: 05UFCaptain] #5215250 09/17/19 12:07 PM
Yah-Tah-Hey Offline
You live in Florida so I would use an ISO-68 hydraulic fluid, but that might be hard to find in the quantity you need. The ATF you mentioned will suffice.
Re: Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX [Re: 05UFCaptain] #5217855 09/20/19 10:23 AM
Thanks for all of the input. When the gallon of Miles synthetic ISO 46 Hydraulic Fluid that I ordered arrives, I'll follow up with anything noteworthy pertaining to BL-700SLX or the hydraulic fluid. cheers
