Left OR Right?
by MolaKule - 05/30/20 01:46 PM
Space X launch
by MrQuackers - 05/30/20 01:33 PM
Rotella Truck 5W-30 Disco'ed at Home Depot
by josephp732 - 05/30/20 01:17 PM
320K mileage - recommendations?
by joshuawesl - 05/30/20 12:36 PM
ISO Sprint sim
by pkunk - 05/30/20 11:44 AM
2001 Mazda Miata, timing belt
by frankbee3 - 05/30/20 11:15 AM
3M tape removal
by loneryder - 05/30/20 10:31 AM
Which string trimmer
by DeafBrad - 05/30/20 10:26 AM
Conventional Oil Benefits
by Bogdon - 05/30/20 07:38 AM
I'm finally retired!
by grampi - 05/30/20 07:20 AM
2020 Equinox 1.5t
by IMPALA08 - 05/30/20 07:05 AM
Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
Dermented, Twostick, davecrobinson, YardWork, Moonray
71577 Registered Users
83 registered members (77GrandPrix, 928, Ag76, 53' Stude, 94astro, 2010Civic, 8 invisible), 2,413 guests, and 31 spiders.
Topics306,048
Posts5,285,628
Members71,577
TPS only seeing 3.7v at WOT #5215190 09/17/19 11:39 AM
J
joegreen Offline OP
J
2000 lexus es300 tps only sees 3.7v at wot. Vehicle computer shows 74% throttle opening at wot. Does that seem correct? Car seems to accelerate ok but i dont want to be leaving performance on the table. The tps sweep is nice with no dead spots. It starts at around .6 and goes to 3.7. Shouldn't it be closer to 5v?
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: TPS only seeing 3.7v at WOT [Re: joegreen] #5215242 09/17/19 12:53 PM
M
mk378 Offline
M
I assume this is a mechanical cable from the gas pedal to the throttle body. Engine off, have someone hold the gas pedal to the floor while you check if the lever on the throttle body can move further open. If it can, adjust the cable accordingly. It must still return all the way to the stop at idle though.
Re: TPS only seeing 3.7v at WOT [Re: joegreen] #5215418 09/17/19 04:26 PM
1
14Accent Offline
1
Toyota lists the following to test the TPS sensor:
OHM's @ 68 degrees F, as measured between terminals VTA and E2:
Closed throttle - 200-6,300
WOT - 2,000-10,200
There is a footnote that says: Disconnect vacuum hose from throttle opener and apply vacuum to allow throttle to fully seat.
I did find a voltage spec, which is .3V to 1.0V at closed throttle, 2.7V to 5.2V at WOT. Your numbers look dead on, according to the service information.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
