Planes fly over white house after speech
by 1978elcamino - 07/04/20 10:16 PM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
People driving less / motor oil prices?
by 1978elcamino - 07/04/20 10:02 PM
Fireworks and dogs
by 555 - 07/04/20 07:52 PM
Cannot unscrew oil filter housing cap - BMW E46
by 97tbird - 07/04/20 07:21 PM
Are u a big fireworks person?
by ZZman - 07/04/20 06:53 PM
Honda Accord MAP sensor question
by Kira - 07/04/20 06:28 PM
Hy-Gard Shelf Life (Opened Bottle)
by viscous - 07/04/20 06:10 PM
Want to bet on my luck? (atf to "save" transmission)
by Snoman002 - 07/04/20 06:10 PM
Too Much Zinc = Corrosion?
by viscous - 07/04/20 06:00 PM
New vehicles with a 4 speed transmission?
by MrHorspwer - 07/04/20 04:57 PM
Inability to Choose
by Gene K - 07/04/20 01:53 PM
65 200 6 mustang running kinda hot
by old1 - 07/04/20 01:30 PM
Neo-protec GT em
by dervdave - 07/04/20 01:19 PM
Mannol 9929 Ester additive
by dervdave - 07/04/20 01:14 PM
2015 Corolla with 7k miles has “soft brakes”
by NHBFAN - 07/04/20 12:30 PM
Put Bilsteins on the Silverado
by bdcardinal - 07/04/20 12:19 PM
SilentC, paolo9fla, SunnyB, Mullady76, Axia2
71848 Registered Users
57 registered members (Alfred_B, 2010Civic, 2009Caraman, Barwich, ammolab, 53' Stude, 3 invisible), 1,019 guests, and 24 spiders.
Topics307,436
Posts5,311,016
Members71,848
motul eco-lite 5w30 #5215012 09/17/19 07:47 AM
A
avi1777 Offline OP
A
hi,
anybody has experienced it and can shed a light on it?
been using castrol magnatec stop start a5 5w30 and loving it because it makes the engine run smooth and quiet,wanted to know if this motul does the same or better in those departments,
tnx a lot.
Re: motul eco-lite 5w30 [Re: avi1777] #5215015 09/17/19 07:48 AM
A
avi1777 Offline OP
A
8100 eco-lite to be exact.
tnx
Re: motul eco-lite 5w30 [Re: avi1777] #5215088 09/17/19 09:10 AM
A
ARCOgraphite Offline
A
Its a good oil but usually pricey. What Auto and engine is this going in ?
I have used 8100 Econ-Nergey in 5W30 grade and it was the best synthetic - though very low viscosity - I've run.
In very cold North East USA Winters (-20C) starting and warmup was like the car was in a heated garage!
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: motul eco-lite 5w30 [Re: avi1777] #5215097 09/17/19 09:24 AM
A
avi1777 Offline OP
A
its for a 2.5 n.a skyactive mazda engine.
can get it 20% cheaper than castrol,valvoline and 50% than m1.
is the eco lite is similar to the energy?
tnx.
Re: motul eco-lite 5w30 [Re: ARCOgraphite] #5215101 09/17/19 09:31 AM
A
avi1777 Offline OP
A
in what way it was the best,have u used castrol,and what do u mean low viscosity?using in israel which is a warm country,summer 40,winter around 10 celsius.
tnk u so much.
Re: motul eco-lite 5w30 [Re: avi1777] #5215364 09/17/19 03:39 PM
P
pbm Offline
P
tnx
I have a liter of this oil from an Amazon mistake (they said it was 12 but only 1 arrived and they told me to keep it).
What current synthetic would be good to mix this with? (similar additive package)...Thanks
'Journalism is Dead'
Re: motul eco-lite 5w30 [Re: avi1777] #5215917 09/18/19 09:13 AM
A
A
tnk u so much.
It should be better for power and economy than the Castrol. I have run Castorl Magnatec It just O.K.
The Motul , Buy it and try it! It is fine for your environment smile
from MOTUL: ECO-LITE 5W30
100% Synthetic Fuel Economy engine oil specially formulated for recent gasoline engines, naturally
aspirated or turbocharged, indirect or direct injection, designed to use engine oil with low friction and
low HTHS (High Temperature High Shear) viscosity (≥ 2.9 mPa.s).
Suitable for modern gasoline engines requiring a viscosity grade 30 and fuel economy lubricant (API
SN and/or ILSAC GF-5 standards).
Approved GM-dexos1™ GEN2 for all new GM gasoline engines requiring this approval: BUICK,
CADILLAC, CHEVROLET, GM, GMC, OPEL and VAUXHALL.
Compatible with catalytic converters.
This type of oil may be unsuitable for use in some engines. Refer to the owner manual if in doubt.
PERFORMANCES
STANDARDS API SERVICE SN
ILSAC GF-5
APPROVALS GM dexos1™ GEN2 under n° D10577HI011
PERFORMANCES CHRYSLER MS-6395
FORD M2C 929-A
FORD M2C 946-A
RECOMMENDATIONS Gasoline engines: ACURA, CHRYSLER, DODGE, FORD, GENESIS,
HONDA, HYUNDAI, INFINITI, KIA, LEXUS, MAZDA, MITSUBISHI,
NISSAN, SUBARU, TOYOTA …
RECOMENDATIONS
Drain interval: according to manufacturers’ recommendations and tune to your own use.
MOTUL 8100 Eco-lite 5W-30 can be mixed with synthetic or mineral oils.
Before use always refer to the owner manual or handbook of the vehicle.
PROPERTIES
Viscosity grade SAE J 300 5W-30
Density at 20°C (68°F) ASTM D1298 0.847
Viscosity at 40°C (104°F) ASTM D445 67.0 mm²/s
Viscosity at 100°C (212°F) ASTM D445 11.4 mm²/s
HTHS viscosity at 150°C (302°F) ASTM D4741 3.3 mPa.s
Viscosity index ASTM D2270 166
Pour point ASTM D97 -39°C / -38°F
Flash point ASTM D92 228°C / 464°F
Sulfated ash ASTM D874 0.85% weight
TBN ASTM D2896 8.5 mg KOH/g
Re: motul eco-lite 5w30 [Re: avi1777] #5215926 09/18/19 09:20 AM
A
avi1777 Offline OP
A
used to run the 300v for years in my sti and definitely going to try it soon,
i believe the magnatec is not bad it has a lower hths but higher tbn maybe due to the a5 spec.
Re: motul eco-lite 5w30 [Re: avi1777] #5216672 09/19/19 03:11 AM
A
avi1777 Offline OP
A
about to put the eco lite in the car,will update how it is.
Re: motul eco-lite 5w30 [Re: avi1777] #5220163 09/23/19 05:24 AM
A
avi1777 Offline OP
A
they both feel the same in my car(surprise)...
Re: motul eco-lite 5w30 [Re: avi1777] #5221108 09/24/19 08:58 AM
A
avi1777 Offline OP
A
it does warm up faster tho then the magnatec,its writen on the bottle and its true.
