Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
California, all trucks commercial vehicles
by Redright9 - 05/27/20 09:47 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
BlackMagicVarian, Mustache, mountaingoat, Alegrianyc, unavailable
71545 Registered Users
44 registered members (carlprop, blufeb95, 928, 2009Caraman, BHopkins, 4 invisible), 1,525 guests, and 54 spiders.
Topics305,955
Posts5,283,619
Members71,545
Mazda CX5 2.5 oil question #5214954 09/17/19 06:54 AM
T
Tallman Offline OP
T
Vehicle is a 2014 Mazda CX5 2.5L with 98,000 km. The maintenance logbook shows all services have been done at around 10,000 km or less.
A quick check on the internet suggest the suggested oil for our 2014 Mazda CX5 2.5L on a number of websites is a 0W-20. The handbook suggests we can use a range of oils from 0W-20 to 10W-50 depending on oil temps. Our local temperature range is -10deg C (14 deg F) to 45 deg C (115F)
In that basis, the manual says we can use either a 10W-50 or maybe a 5W-40 or 10W-40. Options on the oil I should use?
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5214968 09/17/19 07:08 AM
V
vwmaniaman Offline
V
Our Mazda 5 with the 2.5 gets 0-20W all year long runs great, Uses no oil between 5000 mile changes. I use Synthetic in it. Yesterday was hottest day of the year here at 97 F.
Don't waste your time on a slipshod repair.
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5214978 09/17/19 07:19 AM
L
LotI Offline
L
My 6 with the same powertrain was happy on 5w-30 year-round.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
19 Buick Regal TourX
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5214981 09/17/19 07:22 AM
H
Hoot_r Offline
H
I used M1 AFE 0w20 in our Mazda 5 for the first 100k miles without issue, but then again our local temps are a bit milder than yours. Perhaps consider AFE in a 0w30 weight if you're concerned about the higher ambient temps.
2020 Kia Soul LX, 2.0L Atkinson-cycle I-4 (Nu)
Valvoline Advanced Synthetic 5W30, OEM Filter
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215022 09/17/19 07:58 AM
E
E150GT Offline
E
I use 5w30. On 5w 30 or 0w20 my car uses 1 quart per 3000 miles
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215023 09/17/19 07:59 AM
P
pandus13 Offline
P
Guys, Guys,
The OP is in AUS as In Australia!!!
No chance of him getting 0w20 (unless he buys on internet and pays customs taxes...).
I would recommend go with the 5W-40 or 10W-40 available locally, either synthetic blend or synthetic.
Leave it for 6kmiles/10K kilometers. I think the Mazda branded filters are pretty good.
Just check your oil level every other fill-up.
Also, I think these cars like to be driven. So maybe a really early Sunday morning 2 hours run once a month on a the highways? Twisty roads are even better.
At 98k kilometers I would check the AT fluid and maybe do some some drain-and-refill to gently refresh.
Personal experience: I cannot say much since my Mazda5 uses a NA 2.4L engine with NOT the skyaktiv technology.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215029 09/17/19 08:02 AM
PimTac Offline
If the car has been running on 0w20 all along then stick with it. Your cooling system takes care of the heat. Make sure that has been maintained as well.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215043 09/17/19 08:14 AM
E
Eddie Offline
E
I would use a synthetic 5w30 with your temperatures. Ed
2014 CX5 Touring 2.5L :-)
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215067 09/17/19 08:40 AM
carviewsonic Offline
"Our local temperature range is -10deg C (14 deg F) to 45 deg C (115F)"
I would use either a 0w30 or 5w30 for your climate.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215095 09/17/19 09:16 AM
P
Pelican Offline
P
-10 ?! where are you, Snowy Mountains and does it get as high as 45 up there? With that big of a swing I'd use 0W40 synthetic.
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215151 09/17/19 10:49 AM
CT8 Offline
5w-30 or 0w-30
2015 F150 2.7
2018 F350 6.2
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215163 09/17/19 11:02 AM
donnyj08 Offline
If you have a 5w30 or 0w40 available down under I’d use that.
And A5/B5 5w30 would be a good fit IMO.
2008 Silverado LT Z71 101k PP 10w30
2016 Tucson Limited 1.6T AWD 35k M1 5w30 AP
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215174 09/17/19 11:16 AM
K
ka9mnx Offline
K
5w-30 synthetic...
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215213 09/17/19 12:17 PM
V
VQ35DE Offline
V
Mobil 1 AP 0W-20 for me.
2017 Mazda CX-5 GS AWD
2018 Mazda 3 GT
2020 Toyota 4Runner Limited Nightshade AWD
2007 Chevrolet Colorado ZQ8
Re: Mazda CX5 2.5 oil question [Re: Tallman] #5215248 09/17/19 01:03 PM
J
JLTD Offline
J
welcome to this madhouse.
In your climate I would go ahead and use a 5w-40 or 5w-30 year 'round.
Lates.
