Originally Posted By: rg200amp
But back on topic. The use of quality fuel system cleaners used at a "maintenance" dose should "on paper" help to reduce the amount of deposits left behind.
Yep...my theory is the maintenance dose will break apart, and keep apart any foreign material, carbon, desposits, etc...and, in the case of MMO, Seafoam, SL1, keep a light, oiled film over the fuel tank, the filter, and the sending unit, to STOP the formation of crud, deposits, etc..within the tank, and it's other mechanisms....
Quote:
If one uses quality "top tier" fuel with a quality fuel system cleaner all the time, do you think your fuel filter will ever need to be changed??
I'd have to hypothesyze, that YES, the fuel filter would still need to be changed out, or cleaned out over time....though perhaps not at the "typical" manufacturer recommended interval of 30k (for the Purolator, in line fuel filter I just changed out a couple months ago on my 88 Aries...). But yes, contaminants can still make their way into the tank, despite the on-site fuel tanks and fuel pumps having filters....I'm curious how often they actually clean, or change out the filters within the fuel pumps on-site at the gas stations...so yes, debris is still likely to get within the tank I'm willing to bet....dirt, dust, rust (ever see that manhole cover they have to pry up? lol) can still likely get into the on-site tanks....
Quote:
With all those detergents flowing through the fuel filter, one would think not much would be allowed to "build up" in there
Correct. the fuel filter does a job of filtering more than just the carbon, and other contaminants....bottom line, what's in the tank, is going to stay in the tank, til it's taken through the filter. Most fuel systems contain a nylon-type "strainer sock" typically on the in-tank fuel pump....I'm sure that sock does a good job of capturing some of the dirt from going to the injectors, but I think a lot of the FIC used, are generally promoted for cleaning up the carbon on the "combusion" side of things (within the injectors, etc....) and such.
