Prime Guard POF2222 C&P...
T-County, Ohio
Prime Guard POF2222 off my 2010 Chrysler Sebring Touring 2.4l with 191,267 miles. This filter was on the car for 5892 miles. The element was solid with no holes or tears. The rubber anti-drainback valve was still pliable, but was starting to get a bit stiff. This is definitely a single use, 6,000 mile or less filter. But what do expect for a $1.99 oil filter from Rural King? Fill was Harvest King 5w30 full synthetic with another Prime Guard filter. Next time I will change it around the 5k mark.
L8R,
Matt
Originally Posted by 53' Stude
Looks good and thanks for good pictures and post
+1
Sure is. Especially when you consider my oil change only cost me $17 and change after tax. It may be a low end synthetic oil, but it's still carries the Dexos license. But I change my oil between 5500/6000 miles, so I should be good.
L8R,
Matt
Originally Posted by AnthemBassMan
Sure is. Especially when you consider my oil change only cost me $17 and change after tax. It may be a low end synthetic oil, but it's still carries the Dexos license. But I change my oil between 5500/6000 miles, so I should be good. T
L8R,
Matt
Totally agree. I see Rural King now has full syn 0w20 with DEXOS 1 Gen2 license:)
Yep, only the 0w20 and 5w30 oils have the Dexos 1 Gen 2 licensing. I think before they switched suppliers, their 5w20 also had it. Not exactly sure, but I think they changed from Citgo to Warren as their supplier.
L8R,
Matt
