Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
PP on great deal for Canadians this week
by Jimmy_Russells - 11/21/19 04:40 PM
Ford Maintenance Schedule
by borgward - 11/21/19 04:22 PM
hotshot fr3 oil additive?
by dogememe - 11/21/19 02:27 PM
Turtle Wax Hybrid Ceramic
by Toros - 11/21/19 02:01 PM
Need earbud recommendations!
by cwilliamsws6 - 11/21/19 01:50 PM
Snow Shovel Recommendations ?
by Dwight_Frye - 11/21/19 01:29 PM
Torque Wrench Accuracy
by BMWTurboDzl - 11/21/19 12:32 PM
Does Discount Tire sell seconds?
by sasilverbullet - 11/21/19 11:23 AM
Tires for my 2007 Dodge Grand Caravan
by diyjake - 11/21/19 10:26 AM
Fair price for a brake job?
by Ddub - 11/21/19 10:09 AM
Anyone backing up their data online?
by gonefishing - 11/21/19 09:52 AM
Fram Ultra C&P
by mpgo4th - 11/21/19 09:19 AM
2001 Nissan Sentra / trans issue?
by Mark72 - 11/21/19 09:10 AM
CVT Maintenance for CVT Dummies
by Brons2 - 11/21/19 09:00 AM
Wix/ Napa best oil Filters
by edward51956 - 11/21/19 08:54 AM
Mahle OC84, 1974 BMW 2002
by wings&wheels - 11/21/19 08:48 AM
Kylefl1, JDee71, trgfunds, jtowndtk, Bogie247
69934 Registered Users
114 registered members (73Duster, 2010Civic, 2015_PSD, 01rangerxl, Aichiguy, 92saturnsl2, 10 invisible), 2,046 guests, and 27 spiders.
Topics297,734
Posts5,121,652
Members69,934
Most Online3,589
Nov 2nd, 2019
Rate Thread
2006 Toyota Corrolla 1.4 d4d 1nd-tv #5211992 09/13/19 05:46 PM
M
mossietheno1 Offline OP
M
HI all. I made a mistake taking this oils sample was talking to someone when i was planing on taking the UOA.I had the filter its oil and the oil from the sump in the container before i took the test. I am guessing that this will adulterate the results. Does anyone know do the these oil filter catch and keep the particles, do they work like a siv, a paper towel or more sealed then them so that the bits wont go back the way they came from. Could i have let the bits from the filter mix with the oil from the sump and be brought up on the test. I will double check the silicon but this is the second test with this oil using a different that i have a got the same ball park figure for it, 17ppm in the last one so i don't think it is all dirt.
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5212127 09/13/19 09:49 PM
G
Gubkin Offline
G
TBN warning limits <4.0 - good lab!
Not blackstone with 1.0. Where they take this limit nobody no duh
TAN 7.25 > TBN 4.54 - decrease OCI
Soot 1.4% - bad fuel or problem with injectors
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5212129 09/13/19 09:50 PM
G
Gubkin Offline
G
Not blackstone with 1.0. Where they take this limit nobody know duh
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5212137 09/13/19 10:08 PM
G
Gubkin Offline
G
Sorry, delete please
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5212493 09/14/19 12:40 PM
M
M
Thanks for the response. I have been looking up TAN and TBN. i understand now that that the TAN should not go over the TBN. I am still concerned why they don't write that on the sheet. They must assume that the person reading it know.
I will change the OCI to 10,000km. and will come back and update ye. does any one know if I should reduce the OCI further.
Could that level of soot be created by the short journeys. would it be advisable to add in some injecter cleaner.
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5212617 09/14/19 03:42 PM
M
M
Does anyone have any links or info on how much is too much for the by-products, mainly wondering about the sulfation.
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5212931 09/15/19 03:13 AM
I
Ilia Offline
I
i think you should change interval even to 8000 km if you have short journeys.
good injecter cleaner- liqui molly(tested in apl germany), chevron techron/wynns with pea
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5212962 09/15/19 05:13 AM
T
Tikka Offline
T
Hi
I had soot levels of 1.5% on my last Jeep 3.0crd UOA. A forum member posted this link for me to read
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2122499
I put my soot levels down to short runs with a cold engine. Can you get Millers Oils products in Ireland? The Diesel Ecomax is well thought of.
http://www.millersoils.co.uk/products/0/185
Tikka
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5213312 09/15/19 11:52 AM
M
M
Right i will go with 8K as the tan was very high. and in terms of the soot after reading thought the forum posted my tikka, thank you for that by the way it was very helpful. i will not be adding in any cleaner. Does anyone have any idea about the by products i have not found anything about them online.
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5214023 09/16/19 05:10 AM
R
Rollins Offline
R
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/8DF7EB67C6A8566980257F6C0059DA45/$File/BPXE-A7YAPZ.pdf
Acc. to a Russian lab the VO of a Castrol Magnatec A5/B5 has :
TBN 11.62 mgKOH/g per ASTM D2896(ACEA A5/B5 limit is min.8mgKOH/g; max.1.6wt.% SA )
Si 8 ppm
Concerning the by-products (by oxidation,nitration,sulfation) here are two old write-ups worth reading:
https://www.machinerylubrication.com/Read/561/oil-analysis-diesel-engine
https://www.machinerylubrication.com/Read/873/oil-tests
As for diesels you'll see varying condemnation limits among manufacturers (even the warning levels vary with labs). I'd definitely shorten the oil change interval and would be happy if the soot loading is kept under 1wt%.
Check if the intake system is sealed.
Re: 2006 Toyota Corrolla 1.4 d4d 1nd-tv [Re: mossietheno1] #5214263 09/16/19 10:04 AM
M
M
Thank both of them links are very good. will do, i tend to place a plastic sheet or the intake and if it dies the second i do then i assume the intake is leak free.
