fishing licenses on boats
by motor_oil_madman - 10/22/19 10:16 PM
Tokyo Motor Show 2019
by PimTac - 10/22/19 10:14 PM
More Quick Chargers
by Snagglefoot - 10/22/19 09:48 PM
'08 Chrysler Sebring Test Drive
by Fifth87 - 10/22/19 08:42 PM
Testing old coolant
by ARB1977 - 10/22/19 08:20 PM
Pennzoil Maximum Power 0W30
by HoosierJeeper - 10/22/19 07:44 PM
Bought a unknown air rifle and need help.
by jakewells - 10/22/19 07:26 PM
What happens to used cars that don't sell?
by WhyMe - 10/22/19 07:11 PM
No spark
by Eric Smith - 10/22/19 06:57 PM
So you need a new engine?
by Skippy722 - 10/22/19 06:40 PM
Super Hot Fish at local fish monger restaurant
by Cujet - 10/22/19 06:39 PM
Mobil 1 5w30 SN+ D1G2 VOA
by donnyj08 - 10/22/19 06:07 PM
Shell Nitro+ Gasoline in older cars
by Building3 - 10/22/19 05:43 PM
11th UOA, 07 FJ 4.0L, Mobil Delvac 1 ESP 5w40
by jetman - 10/22/19 05:42 PM
OPG vs. NPD for parts
by 007 - 10/22/19 05:01 PM
Anyone else here driving something with CNG?
by atikovi - 10/22/19 04:56 PM
Questions aftermath of oil change
by messerschmitt - 10/22/19 04:55 PM
What bearing grease for off road vehicle?
by Enigma - 10/22/19 04:19 PM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
75 registered members (379KITTY, 92saturnsl2, AC1DD, 1960Elco, 4WD, 6 invisible), 1,729 guests, and 32 spiders.
Topics296,357
Posts5,096,259
Members69,652
Most Online3,532
Jul 30th, 2019
Engine tick on startup #5214141 09/16/19 08:44 AM
B
Broo Offline OP
B
Car is question is a 1984 Supra with a 5MGE inline 6 engine, no mods whatsoever.
My car developed a startup ticking noise about 3 years ago.
I run my car only once every weekend for a long drive. At startup, there will be a tick tick tick noise (don't know how do describe it better, but it's definitely mechanical and coming from the engine) for about 4 to 5 seconds then goes away.
Starting the car while warm doesn't do this, and it also doesn't happen if I start the car the next day. No noise either on idle. It seems to take a couple of days off to do this noise on startup.
This leads me to think it might be due to the oil draining down. When it began doing this, I was running a genuine Toyota oil filter, the next year I switched to a Wix and it still does that noise. I don't think I could have got 3 faulty anti-drainback valve filters in a row over 2 brands.
I've had the car for 9 years now, always ran the same oil type, Castrol GTX High Mileage 10W30. I change the oil every year, so it's about a 3000 KMs (1800 miles) interval. Engine is currently at 174000 KMs (108K miles). No noticeable smoke.
The problem didn't get any worse since it began 3 years ago.
What might cause this and will that damage the engine over time ?
Re: Engine tick on startup [Re: Broo] #5214154 09/16/19 08:58 AM
L
Lapham3 Offline
L
It sounds like a hydraulic lifter is bleeding own over time and takes a bit of time to pump back up upon startup.
Re: Engine tick on startup [Re: Broo] #5214155 09/16/19 08:58 AM
A
ARCOgraphite Offline
A
Likely HLA pumping up. Also Sometimes V belts and idlers make a racket as they loose their wrap memory.
Just know that most all engines make racket whilst warming up. Only excessive and long lasting racket could be a concern.
I don't recall if this is a dry timing engine. Has the cam Timing system been refurbished since you have owned the car?
Also you don't have to change the oil every year - it doesn't help and may hurt.
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#7 52665mi-Castrol GTX Magnatec 5W20 + SOA Filter
Re: Engine tick on startup [Re: Broo] #5214172 09/16/19 09:15 AM
Astro14 Offline
Hydraulic lifter has lost its pump.
Or, exhaust manifold leak.
Exact same symptoms.
Given the car’s age, could be either.
A stethoscope would be a great investment.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Engine tick on startup [Re: Lapham3] #5214177 09/16/19 09:19 AM
T
Trav Offline
T
+1 That is with 99% certainty what it is on this engine.
OP This causes no damage long or short term, on some engines its totally normal, probably just a little varnish in them. You could try running a 16oz bottle of Rislone high mileage the next oil change for a full OCI, if it makes it better fine if not forget it.
With an engine this age I would be a little cautious with strong solvent type additives, the Rislone HM seems to do a pretty decent job for a few bucks from Walmart.
I have some seals of different type materials including some old school neoprene ones sitting in it for the last 3 months with nothing to report, no change in size or suppleness.
