Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
18 registered members (blufeb95, 4WD, ctechbob, BusyLittleShop, FordBroncoVWJeta, BlueOvalFitter), 1,079 guests, and 41 spiders.
Topics305,999
Posts5,284,442
Members71,558
Centrifuge and filtering effects on additives #5212663 09/14/19 06:10 PM
P
PapaSquat1 Offline OP
P
Ok I have a bit of a different one;
Anyone know of any practical resources for determining how and when additives are forced out of oils by a centrifuge or filtering?
We use a straight cutting oil in machines cutting metal, the oil drips of the metal scrap and gets put back in the machine.
The cutting oil is normally a mineral oil (group III) with an inactive sulfur EP and some DiEster added.
Currently the oil gets filtered to 5micron and reused.
Over time the machine slide lubricant oil, a heavily iso68 with a tackifier and its own aw/ep additives, bleeds into the cutting oil.
I wanted to try to use a WMO centrifuge to remove the metal fines and any disolved sludges in the centrifuge... Rather than having them redeposit in the machine.
I heard murmurings of centrifuges even at 1000G's will pull out additives?
Our oil rep says 2micron is the limit for depth filtering, otherwise the EP will be removed.
Thanks guys
Re: Centrifuge and filtering effects on additives [Re: PapaSquat1] #5212712 09/14/19 07:29 PM
I
Imp4 Offline
I
This is the definition of chasing one's tail....
Change it out once it starts to stink, even after filtering.
Otherwise, too many variables to have an intelligent discussion.
Re: Centrifuge and filtering effects on additives [Re: PapaSquat1] #5212754 09/14/19 08:47 PM
Cujet Offline
https://www.alfalaval.com/industrie...ube-oil-treatment/lube-oil-cleaning/faq/
Quoted answer from Alfa Laval:
" Q: Will the additives in the lube oil be destroyed with centrifugal separation?
A: No, the molecular alliance of the additives with the oil is stronger than the centrifugal force. "
I have an Alfa Laval Emmie, a 5000G, centrifugal separator. It's an amazing device and it will absolutely pull water, various common contaminates and bacteria from jet fuel with perfection. It can also bring aging gasoline back to life by removing the gums and varnishes. I tried it on used motor oil with poor results, (even when diluted with jet fuel) , despite the claims that it can effectively filter lube oil. It cannot pull carbon and soot out, as the density of carbon particulates is not sufficiently different from the motor oil. It removed some wear metals and water from used motor oil, but the soot remained entirely.
The centrifuge can only remove particulates and components that are more dense than the oil or fluid itself.
Re: Centrifuge and filtering effects on additives [Re: PapaSquat1] #5212821 09/14/19 10:19 PM
K
kschachn Offline
K
And this is not "Ok I have a bit of a different one", the subject has been discussed on here more than once.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Centrifuge and filtering effects on additives [Re: Imp4] #5213993 09/16/19 04:17 AM
P
P
The
The thing is in a cutting oil application the oil will be loaded with metal fines well before the oil goes bad, the oil will look brass or alum colored (depending on the material cut) even after settling for awhile, and it takes very little energy to get what does settle mixed up again.
