I admit that ATs have always been something of a magic black box to me with understanding how they work.
I have a relatively new to me car with a BW35 behind an anemic 1.8L pushrod engine that probably generously makes 75HP, which I know isn't exactly the most spirited driving combinations. A potential manual swap is under consideration, and I'm afraid it may happen sooner rather than later.
In any case, the car hasn't been driven in 10 years, and I finally got it to the point where I felt safe enough to take it around the block today. I SHOULD have done an ATF change before taking it out, but that got shuffled down in priorities and I may now be regretting it. My "around the block" is up a steep hill(about a half a mile) and then back down. At the end, I have to stop to open a gate, and then go ~30 feet up a hill to park.
All was going well until I had to stop(if I hadn't had to open the gate, I probably could have coasted in). In any case, it seems to either be slipping BADLY or it's not starting/going into 1st gear even with the selector at "1". Basically, I couldn't get it to move up the hill no matter how much I revved it. If I backed up to flat ground, I could build a bit of momentum and get it a few feet up the hill, but I couldn't get more than halfway up(I ended up with a bunch of people helping me push it up to get it up). With it back level now, I can get a sluggish few feet of forward and backward movement, which is as much as I dare before I get back to an incline(I don't want to have to keep asking neighbors for help pushing).
Is there anything easy I could try other than a fluid change on this? I REALLY don't want to pull the transmission out now...
