Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
88 registered members (97 GTP, 2KBMW, 14Accent, 4WD, AandPDan, ammolab, 7 invisible), 2,114 guests, and 60 spiders.
Topics306,095
Posts5,287,309
Members71,596
Fall Dilution #5213611 09/15/19 05:56 PM
Snagglefoot Online Content OP
OP Online Content
Did my Fall dilution today. Vacuumed out 3-1/2 quarts of trans fluid, Turkey basted about 3/4 quart of brake fluid and about 3/4 quart of power steering fluid. Replaced them with the fluids shown. I have two different turkey blasters for the removing the brake fluid and PS fluid. I’ll bleed the brake fluid next time I do the brakes as well as do a pan drop and new filter in another year. Enjoy.( Canadian part numbers shown on the AC Delco fluids.) Enjoy. Beer2
If you want the job done right......do it yourself.
Re: Fall Dilution [Re: Snagglefoot] #5213766 09/15/19 08:36 PM
M
mjk Offline
M
Did you evacuate the Blinker fluid as well ?
Re: Fall Dilution [Re: Snagglefoot] #5213770 09/15/19 08:39 PM
A
Aero540T Offline
A
I did all three just like you on my 2002 Taurus at 196k miles. Mostly because I had time between jobs and the fluids on hand. Peace of mind
2004 Jeep Grand Cherokee Limited 4.7L (wife’s) PUP & FU
2002 Ford Taurus 24V M1HM & M1EP
2001 Dodge Ram 1500 5.9L 4x4 10w-30 RP & FU
1993 Yamaha FZR 600
Re: Fall Dilution [Re: Snagglefoot] #5214019 09/16/19 05:52 AM
M
Mad_Hatter Offline
M
For the PSF, i don't even waste time with a turkey baster. This method 👇you can replace the entire system in about 20mins. The clear tubing's about $8 and the fitting is about $5, both on Amazon. This is how I do it.
You can do it by yourself but if you have a helper it goes lickity split. My son keeps the reservoir full while I turn the wheel lock to lock otherwise I'd have to get out and check the reservoir. Easy peazy, lemon squeezy... alternatively, you could use a pump/evacuator to pull the PSF out (no having to turn the steering wheel lock to lock). You just need to jury rig an (adaptor) line to mate to the return line. I've seen mighty vac setups do this but I'm sure you could rig up an el cheapo hand pump to do the same with the right parts.
Re: Fall Dilution [Re: Snagglefoot] #5214404 09/16/19 01:43 PM
P
Pew Offline
P
Does the PS fluid have to be changed? I've never heard of anybody doing one on the Evos when I had one so I never thought about doing one on my focus.
Re: Fall Dilution [Re: Pew] #5214433 09/16/19 02:21 PM
M
Mad_Hatter Offline
M
My OM says inspect every 18 months. When I learned this easy way to replace it, I just replace every 2yrs now no matter what. And for me it's cheap. I just use MaxLife and it takes about two qts give or take to flush the old fluid out of the system and get all bright red fluid in there.
