Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
89 registered members (2KBMW, 14Accent, 4WD, 830Lee, 2010Civic, 77GrandPrix, 8 invisible), 2,040 guests, and 65 spiders.
Topics306,094
Posts5,287,299
Members71,596
Cleaning slider pin bore #5213605 09/15/19 05:49 PM
G
greasegunn Offline OP
G
I’m curious on how everyone else cleans the slider pin bore - especially after the pin has been stuck. I typically clean with a wire brush and brake cleaner until the brake cleaner is coming out clean. Then dry with compressed air. Is there a better way? Is there an easier way?
Re: Cleaning slider pin bore [Re: greasegunn] #5213637 09/15/19 06:20 PM
U
UG_Passat Offline
U
On my car, it's rubber, so I don't have that problem.
You should try a hex-shank tube brush and attach it to a drill. It would make short work of cleaning.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Cleaning slider pin bore [Re: greasegunn] #5213639 09/15/19 06:21 PM
J
Jason_Michaels Offline
J
https://youtu.be/g99MRwTcndc
about halfway thru he shows his tips for bore cleaning
Re: Cleaning slider pin bore [Re: greasegunn] #5213717 09/15/19 07:53 PM
Snagglefoot Online Content
Online Content
Good video. Thanks for the post.
If you want the job done right......do it yourself.
Re: Cleaning slider pin bore [Re: greasegunn] #5213752 09/15/19 08:28 PM
slacktide_bitog Offline
If a slide pin seizes, I replace the caliper smile
Otherwise, I just re-grease them. But I am considering replacing the slide pins every time from now on
Re: Cleaning slider pin bore [Re: slacktide_bitog] #5214176 09/16/19 09:19 AM
P
painfx Offline
P
Why would you want to replace them, if they are not seized? If you lube them properly with silicone, the chances of seize pins would be slim.
Re: Cleaning slider pin bore [Re: Jason_Michaels] #5214275 09/16/19 11:19 AM
G
G
Thanks for the video. Enjoyed it!
Re: Cleaning slider pin bore [Re: UG_Passat] #5214277 09/16/19 11:25 AM
G
G
Thanks for your feedback. I use a hex shank tube brush (HF) but don't put it y on a drill. In the future I think I will start with a drill bit like in the video below and then follow up with the brush.
Re: Cleaning slider pin bore [Re: painfx] #5214389 09/16/19 01:29 PM
Because there is still too much of a chance of them seizing, and I hate rust cry
Re: Cleaning slider pin bore [Re: greasegunn] #5214496 09/16/19 04:03 PM
N
nthach Online Content
Online Content
N
I pull the pins out and spray in some brake cleaner. Then use a piece of paper towel wrapped around a screwdriver or drill bit as a "tampon" of sorts to clean the bore.
Someone told me a soft gun bore brush also works too. I might do that next time. I don't use that Permatex green/lilac crap on my brakes or anyone elses/
Re: Cleaning slider pin bore [Re: greasegunn] #5214544 09/16/19 05:42 PM
H
hallstevenson Offline
H
Was just going through my "plumbing stuff" bin and ran across one of these
[Linked Image from p1.cdn.hardwareandtools.net]
Think that would work for cleaning the bores ?
Re: Cleaning slider pin bore [Re: greasegunn] #5214561 09/16/19 06:00 PM
N
Online Content
N
You want something small and non-scratching to the bore. That fitting brush is too big.
Re: Cleaning slider pin bore [Re: nthach] #5216244 09/18/19 02:50 PM
Yah-Tah-Hey Offline
You got that right nthach. That green,red, purple goop will swell those pin bushings to where they are very difficult to remove.
Re: Cleaning slider pin bore [Re: slacktide_bitog] #5216580 09/18/19 09:36 PM
P
painfx Offline
P
What state are you from?
Re: Cleaning slider pin bore [Re: greasegunn] #5216680 09/19/19 03:59 AM
ctechbob Offline
Brass firearm bore brush of the appropriate size should do the trick. Mounted on a drill or not. Shouldn't hurt a thing so long as its an iron bore and not a rubber lined one.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
