Replaced front shocks
socal
New to me 04 Avalanche Z71 4x4. Wanted to put a mild lift from stock height so I went w 2" new torsion keys and Longer bilsteins 5100s up front. In the rear, added a 1" spacer. The previous owner had Pro Comp adjustable MX6 shocks on the rears so I kept them for now. Rides good and I think it looks perfect, not a like a broh truck
[Linked Image]
[Linked Image]
[Linked Image]
Nice, clen looking truck.
Is it just a bit tall up front?
NO Fogs or spots on the roll bar?
You have to do a front end alignment afterwards?
Don't forget to get an alignment.
Changing ride height means the toe-in/out will be off. Steering wheel will probably be straight but you'll get worn tires.
Does it look high up front because of the the front wheel gap being larger? Could that just be the lighting or the angle of the shot?
Either way, it looks a little weird on those tires. It looks like you are rolling on car tires now!
Not a roll bar on an Avalanche, it's stock plastic decoration.
Nose high is the normal socal prerunner look. Looks good, might need a bit more tire now. Please don't Plastidip the stock wheels black.
